Update CSV linked to Surveys via script
3212
11
08-19-2024 12:16 PM
DuncanC
I want to automate the updating of the CSV files my surveys use.  But I cannot find a way to do the equivalent of pushing update data button in the online portal via script.  Using either the REST interface directly or the python SDK I can download the CSV, but I can't find a method to replace it with new data.
I could delete it, and upload a new copy, but that will have a new ID and I'm pretty certain it's not going to be linked to my surveys.  I've looked into adding a link to the new ID as linked content on the surveys via python, but that also looks to be a dead end and not available.
Hoping I'm just missing something and there is a way to do this.  Any advice would be greatly appreciated.
AmeWunderle
Hi Duncan,
I run a daily python script  to update a csv that I reference in one of my surveys in Survey123. I also only use AGOL not enterprise.
The steps I follow are:
1. re-create the csv locally exactly how it is in AGOL so that you can use the update method on the csv in AGOL
2. run the following script
import datetime
from arcgis import GIS
from arcgis import features
from arcgis.features import FeatureLayerCollection
import datetime
import sys
# Connect to the GIS
gis =  GIS(profile="") # Your profile name
token = gis._con.token
# set variables and access json
csvID = ""  # the id number of your csv
csv_item_title = "" # the title of your csv
localfile = "" # the local path to your file you wish to replace the csv with
currentdate = datetime.date.today()
# set log file for data logging
fp = open("","a") # set up a log file as this is never a bad idea
# Query to see if item exists
print ("...Searching for feature service...")
the_services = gis.content.search(query = 'title:' + csv_item_title + " AND " + 'id:' + csvID)
if len(the_services)!=1:
    print("Couldn't find feature service" + csv_item_title+ " in AGOL. Exiting script")
    error_message = currentdate.strftime("%Y/%m/%d")+','+'csv not found\n'
    fp.write(error_message)
    fp.close()
    sys.exit()
print ("....found feature service " + csv_item_title+ " in AGOL")
#Update CSV Table in AGOL from local CSV file
fs = gis.content.get(csvID)
try:
    fs.update(data=localfile)
    print (".....updating csv file in AGOL")
except:
    error_message = currentdate.strftime("%Y/%m/%d")+','+'update in AGOL not successful\n'
    print ("..error in updating csv file. Exiting script")
    fp.close()
    sys.exit()
# write the success to the log file
message = currentdate.strftime("%Y/%m/%d")+','+'Yes\n'
fp.write(message)
fp.close()
print("Script successful")
HannesVogel
Hi @DuncanC
my colleague is using FME Flow - maybe here is a good starting point: https://community.esri.com/t5/arcgis-data-interoperability-blog/how-fme-flow-or-form-can-write-to-ar...
DuncanC
Thanks for the suggestion.
I should have mentioned I'm using AGOL not a enterprise install so I don't think that solution works.
HannesVogel
if you have the FME possibility there is an AGOL connector as well: https://support.safe.com/hc/en-us/articles/25407563623565-How-to-use-the-EsriArcGISOnlineConnector
DuncanC
I'm not interested in the FME part, but if their connector can do what it claims it give me hope that what I want is indeed possible, I just need to find the correct REST endpoint.
AmeWunderle
Hi Duncan,
import datetime
import datetime
import sys
    fp.close()
    sys.exit()
try:
except:
    fp.close()
    sys.exit()
fp.write(message)
fp.close()
DuncanC
Thank you very much!!  Not sure how I missed that earlier today but your script helped me find the update method I need.
https://developers.arcgis.com/python/api-reference/arcgis.gis.toc.html#arcgis.gis.Item.update
ChallagundlaSindhuraITS
Hi, How can i get the csvID?       csvID = ""  # the id number of your csv
AmeWunderle
Hi there,
The csvID in the script is simply referring to the item id of the csv. There are a couple of ways to find it, but generally I go to the information page of the item, and grab the id from the URL or you can copy the Item ID directly from the Overview. It's listed under Details on the right hand side.
Hi, Thnak You for the reply! Somehow i am not able to find it. Here is my scenario: The Survey123 form is created by other user(He is the owner of the form, but have given me permissions to edit and all). I sent the user csv file everyday. The user grabs the csv file puts in the media folder,  and clicks the publish button on the Arcgis Survey123 connect. My job is to automate the process using .py script.  if i try to grab the ID from the form URL and see its type it says its not the type CSV. I even tried searching with the CSV file name , but no luck. Please advice! Thanks
