Survey123 calculations not working in edit mode
7348
14
04-09-2021 08:57 PM
KimberlyMcCallum
Hi All,
I am using the embed widget in Experience Builder to embed surveys so that I can click on a map feature and open a survey built on the service (in edit mode). Basically, I adapted this example of a QA/QC workflow using a Dashboard to Experience Builder (https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-embedding-a-survey...). This just uses the URL parameters and the Global ID to open the survey for editing. The app and survey looks great and I am able to submit data BUT the calculations are not working in the embedded survey!
After some investigation, I have figured out that the issue seems to be with calculations in edit mode. The calculations work for new records; however, when I open an existing record to update it (in edit mode), I see the 'Recalculate' button; however it does not work!
Admittedly, the calculation is a bit complicated and awkward as I'm trying to calculate Risk from a risk matrix (see screenshot). Here is the calculation:
if(((selected(${DamageOrLossProbability},'VeryLikely') and selected(${ConsequenceMagnitude},'Major')) or
    (selected(${DamageOrLossProbability},'VeryLikely') and selected(${ConsequenceMagnitude},'Moderate'))
    or (selected(${DamageOrLossProbability},'Likely') and selected(${ConsequenceMagnitude},'Major'))),
    'VeryHigh', if(((selected(${DamageOrLossProbability},'Likely') and selected(${ConsequenceMagnitude},'Moderate')) or
    ((selected(${DamageOrLossProbability},'Possible')) and selected(${ConsequenceMagnitude},'Major'))),
    'High', if(((selected(${DamageOrLossProbability},'Unlikely') and selected(${ConsequenceMagnitude},'Major')) or
    (selected(${DamageOrLossProbability},'Possible') and selected(${ConsequenceMagnitude},'Moderate'))), 'Intermediate',
    if(((selected(${DamageOrLossProbability},'VeryLikely') and selected(${ConsequenceMagnitude},'Minor')) or
    (selected(${DamageOrLossProbability},'Likely') and selected(${ConsequenceMagnitude},'Minor')) or
    (selected(${DamageOrLossProbability},'Possible') and selected(${ConsequenceMagnitude},'Minor'))) or
    (selected(${DamageOrLossProbability},'Unlikely') and selected(${ConsequenceMagnitude},'Moderate')), 'Low', 'VeryLow'))))
Thanks in advance,
Kim
JasminePrater
What I did to solve this issue was to remove the read-only status from those fields.  When it's set to read-only, it doesn't give you an option to manually update them, so they automatically calculate each time.  However, when you remove that requirement, you get a button that allows you to choose whether to keep the original value or recalculate.  It's a little backward, but it worked for me.  The only downside is that you get a large Recalculate button for that question, but at least it saves the original result.
chelynnes
The yellow fields are the ones the customer can see and are not allowed to be manually calculated.
Total time is calculating 2 hidden fields. Even when I took the read only off of the Total, it still didn't calculate.
JessicaJThompson
Hi All,
I am having the same issue. Unfortunately I cannot make the question a read only because it calculates three different options based on prior selection. Two are "defaults" and the third calculation is a blank - allowing the user to make a manual selection.
I am going to try to follow the bug and see if we can get some progress on it.
Thanks for all of the ideas and solutions.
-Jessica
mwartman_grey
I have the same issue.
I am trying to open a survey in edit mode, and have a date/time field automatically update on an existing record. However, I still see the recalculate button in the web form and the old date is displayed. In Survey123 Connect, the [IssueDate] field is set to calculate to =now(). I've tired to recalculate other calculate fields and none of them will auto-calculate when the form is opened. Web form was published using the latest version of Survey123 Connect (3.16)
Here is my url with parameters:
https://survey123.arcgis.com/share/167df9fb24694a0da5c66b5bdeea1dac?mode=edit&globalId=70268755-16a8...
I believe I correctly followed the syntax from this blog post. I also noted that the following error is showing in the browser console:
mwartman_grey
Updated January 9, 2023. The url parameter ?forceRecalculate is now ?recalculate
