Survey 123 Report Template Error: An error occurred when checking the report template. Failed to parse
2121
04-21-2022 05:22 PM
by Anonymous User
Not applicable
Good night, I noticed that there are more problems related to this one, I try to post it but it always generates the same error
how can you help me to solve this problem?
thanks
2 Solutions
Katie_Clark
After a quick glance, I believe it's because you're trying to reference ${aa} inside of the repeat (in the report template), but in the xls form that question is not part of a repeat.
Looks like ${aa} is declared in row 36 and the repeat isn't created until row 56 of the XLS form.
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
by Anonymous User
Not applicable
hello the problem was in the type of name applied in the settings tab
the correct
form_title form_id
POQExecucao POQExecucao
the wrong
form_title form_id
POQ_Execução POQ_Execução
Katie_Clark
Best,
Katie
by Anonymous User
Not applicable
the correct
form_title form_id
the wrong
form_title form_id
