All,
I need help with some grid questions regarding survey123. I'm trying to create a form (survey), with a 2 subgroups. I typed 'w4' into their appearances to try and get them to stretch to the entire form, but they just end up stacking up next to each other. Please advise.
Hi @AaronBrown3,
What version of Survey123 Connect and field app are you using?
Can you share your XLSForm (xlsx file and any media folder files) so we can take a closer look?
With grid theme you need to ensure the w appearance is applied to all groups and questions inside those groups if you want to set different widths.
Please refer to:
and
There is a sample in Connect that also demonstrates using groups and repeats with grid theme.
Regards,
Phil.
I did apply the w appearance to all. what im referring to is the dumptruck and extra trailer portions
I know the 1.33 don't work, but i assumed that it wouldn't be the cause of it anyway given that I edited them and it didn't change anything.AaronBrown3_1-1631555250358.png
