pass name and the label from select-one pull table
1479
08-22-2022 11:47 AM
AndrewPriest
hi, I'm guessing this is an easy one, but it's got me stumped. I'm pulling a .CSV for a select_one question. it's passing the name fine, but I also want to pass the label value to the point feature class. would the jr:choice-name formula pass both? or is there a way to set up some sort of table join? thanks
Tags (1)
ZacharySutherby
Hello @AndrewPriest
The jr:choice-name() function is the way to extract the choice label from the selected choice. You could store the label in a separate hidden question (field in the feature service), or concatenate the choice name from the select_one question and the choice label using the jr:choice-name() function in a separate question (field) to store both in the same location.
Thank you,
Zach
LaurenceTait
What do you mean when you say that you are pulling a .CSV for a select_one question? Do you mean that you are using the select_one_external function? Or that you are setting the default for the select_one question using a a pulldata function? Or that you are using the answer from the select_one in a pulldata calculation in another field?  Or something else?
AndrewPriest
hello. the question type is:
select_one_from_file MySpreadsheet.csv
the .csv is in the media folder
the calculation is:
pulldata('MySpreadsheet','name','label', ${Field})
thanks for the reply! any insight on how I can calculate the Label in a new field would be greatly appreciated
LaurenceTait
OK, I think see what you're doing.
There's two ways of calculating the label in a new field. You can either pull the label from the csv or use jr:choice-name to calculate it from the selected answer.
Example attached below
AndrewPriest
Thanks! I'll give it try
