Filtering integers broken after October 25 2022 update?
3190
19
10-26-2022 05:57 AM
RobBlash
I'm getting an error when filtering on integer fields this morning. This was working fine prior to the update yesterday. Anyone else? I'm going to submit a support ticket but also posting here to see who else is having trouble.
Hussam_AlJabri
Occasional Contributor III
I'm facing the same.
Please consider resolving the issue, as we have many dependencies.
Comisión_Estatal_de_Aguasde_Qu
New Contributor II
Hi! We have the same error in  all our surveys.
TypeError: Cannot use 'in' operator to search for 'name' in 2362611
ZhifangWang
Hi ALL,
The Survey123 Beta website https://survey123beta.arcgis.com has been updated with the fix to this issue. Can you please help test if the Beta website works for your workflow?
If everything looks good, we will deploy the fix to the production website on 10/31.
GIS_Fox
Good morning @ZhifangWang , I ran the workflow on the beta site and did not get the previous errors i've been encountering using filter or "contains" in the filter. I can go further in detail or complexity to test it but so far the fix appears to be working.
Looking forward to the 10-31 patch/update. Many thanks,
Jansen Lyons - Records and GIS Section - Public Works - City of Rio Rancho, NM
SamuelFirmenich
New Contributor II
Good morning @ZhifangWang, I tested the filter as well and it's now working in the beta website.
This is vital to our workflow in Survey123. We're looking forward to the patch/update as well on 10/31. Thanks!
Sam
DavidMichaels
yes the fix on beta is working for us - thank you
Hussam_AlJabri
It is working in the beta. Please update the production as we need it so badly.
regards,
JeffLegato1
The beta site is working for us.
ZhifangWang
Hi ALL,
The fix to this issue is available on the Survey123 website https://survey123.arcgis.com now.
Thank you ALL again for the feedback and tests on the fix.
Best,
RobBlash
Thank you, I am seeing the expected behavior in the Survey123 website this morning.
