Choice Filter Rule Not Being Honored on Attachment (Image, File) after Oct 25th Update
1925
5
10-26-2022 11:42 AM
KarinaLivingston
In Survey123 Web when setting a rule on a choice question to show a media/file question the media question is not showing as expected based on the rule. Other questions like text, date, and time seem to be working. This was working prior Oct 25th update.
IsmaelChivite
Esri Notable Contributor
Thanks @KarinaLivingston  I can reproduce this. We will look into it.
ZhifangWang
Hi @KarinaLivingston ,
The Survey123 Beta website https://survey123beta.arcgis.com has been updated with the fix to this issue. Can you please help test if the Beta website works for your workflow?
If everything looks good, we will deploy the fix to the production website on 10/31.
KarinaLivingston
Hi @ZhifangWang,
I tested the beta version on AGOL and Portal and they both worked! Our workflow that broke was on Portal but we replicated the issue on AGOL as well. Thank you!
ZhifangWang
The fix to this issue is available on the Survey123 website https://survey123.arcgis.com now.
Thank you again for the feedback and tests on the fix.
Best,
KarinaLivingston
Thank you!
