I'm getting an error when filtering on integer fields this morning. This was working fine prior to the update yesterday. Anyone else? I'm going to submit a support ticket but also posting here to see who else is having trouble.
I'm facing the same.
Please consider resolving the issue, as we have many dependencies.
Hi! We have the same error in all our surveys.
TypeError: Cannot use 'in' operator to search for 'name' in 2362611
Hi ALL,
The Survey123 Beta website https://survey123beta.arcgis.com has been updated with the fix to this issue. Can you please help test if the Beta website works for your workflow?
If everything looks good, we will deploy the fix to the production website on 10/31.
Good morning @ZhifangWang , I ran the workflow on the beta site and did not get the previous errors i've been encountering using filter or "contains" in the filter. I can go further in detail or complexity to test it but so far the fix appears to be working.
Looking forward to the 10-31 patch/update. Many thanks,
Good morning @ZhifangWang, I tested the filter as well and it's now working in the beta website.
This is vital to our workflow in Survey123. We're looking forward to the patch/update as well on 10/31. Thanks!
Sam
yes the fix on beta is working for us - thank you
It is working in the beta. Please update the production as we need it so badly.
regards,
The beta site is working for us.
Hi ALL,
The fix to this issue is available on the Survey123 website https://survey123.arcgis.com now.
Thank you ALL again for the feedback and tests on the fix.
Best,
Thank you, I am seeing the expected behavior in the Survey123 website this morning.
