error 999999: error executing function, execution failed
17750
14
06-24-2021 05:42 AM
ArminAzad
Hi, I am new and try to use ArcGIS tools. When I try to use a tool, say fill tool (a tool which corrects the elevation), the ArcGIS works correctly when I work on a single DEM.tif grid. However, when I use a merged picture, it fails. Can anyone kindly guide me?
2 Solutions
JayantaPoddar
By "Merged Picture", are you referring to a mosiac dataset? Do the Mosaic Dataset display correctly on ArcGIS Pro.
Could you try setting the Parallel Processing Factor (Tool Environments) to 0 (zero), and run the tool again?
Think Location
ArminAzad
Hi again Jayanta,
It worked. At first time, I went to "Environments" in the Fill tool window. It did not work. But this time, I went to "Geoprocessing>Environment>Parallel Processing Factor > puting 0"
I really appreciate your help.
JayantaPoddar
Think Location
ArminAzad
Hi Jayanta, thank you for your reply. No, setting Parallel Processing Factor  to zero did not work. I first downloaded four dem files with extension of tif. Then, I merged mosaic files to single file using "Mosaic to Raster New Raster" tool.
I even sent the merged single file to my friend. His ArcGIS could work with that file and do fill tool, but my ArcGIS fails!
Do you have any idea why it happens? I have a project and really need this! Thank you
JayantaPoddar
Could you share screenshot of the error(s) and messages like the filepath of input and output? Avoid using spaces, special characters (except underscore) in filepath, and keep them short, and store them in local drive.
e.g.: C:\Data\Rasters\ElevMos.tif
Think Location
ArminAzad
Dear Jayanta,
I uploaded what you asked. I really appreciate your help.
JayantaPoddar
Not sure what is that "Image Server..." error.
Restart ArcGIS Pro, if not already done.
The length of output filepath looks fine. Could you save the output as a TIFF (DEM2.tif)?
Also put the parallel processing factor as 0 (I know I am being stubborn on this point 😐 ).
Think Location
ArminAzad
It is image server is not supported by the current license.
I did all other tips. They did not work, unfortunately.
JayantaPoddar
Just realized that you are working on ArcMap, not ArcGIS Pro.
Please ensure the background processing is turned off as well (Geoprocessing > Geoprocessing Options).
I am out of any more ideas. If the issue still persists, maybe log a case with Esri Technical Support.
Think Location
ArminAzad
Previous pictures seem to have low quality. SO, I am sending new ones.
ArminAzad
Hi again Jayanta,
