Oriented imagery has transformed how field photos are used in GIS workflows. With ArcGIS QuickCapture, we made it incredibly easy to capture the metadata needed to support oriented imagery—such as location, heading, pitch, and roll—without adding complexity for field users. This means every photo collected in the field can be more than just an image; it becomes a spatially aware resource that can be explored in context, projected onto a map, and analysed from multiple angles.
By enabling Oriented Imagery Layer in QuickCapture projects, authors can unlock powerful capabilities like situational awareness, asset inspection, and immersive visualisation. The best part? It takes only seconds to enable, and QuickCapture automatically handles the heavy lifting—capturing all required properties behind the scenes. This integration allows field users to keep their workflows simple while making their photos far more useful and actionable across the ArcGIS platform.
Note: The QuickCapture Designer does not create an Oriented Imagery layer item. Instead, it creates a layer view from the original QuickCapture project layer. This layer view contains the properties required for use with the new Oriented Imagery clients.
The retirement of the Oriented Imagery Catalog (OIC) item is approaching fast and with it comes the deprecation of the oriented imagery clients that you have been working with. Of note is the fact that with the February 2026 ArcGIS Online release, the Oriented Imagery Classic widget will be removed from Experience Builder, and support for OIC in the JavaScript SDK will end. If your workflows depend on these clients, you must now migrate to the newer integrated capability.
The integrated capability uses the new Oriented Imagery Layer, which offers much better ArcGIS platform integration and long-term support and enhancements. The good news for QuickCapture users is that the option to enable layers for this capability has been available since 2024, and the transition process from an existing OIC catalogue to the new layer type is simple — here’s what you need to know.
The migration process involves creating new fields in the point feature layer (to accommodate schema changes), mapping the appropriate QuickCapture variables to them, and copying values from old fields to new ones if features already exist. Finally, a new point layer view with the properties of an Oriented Imagery Layer item will be created, ready for use in modern oriented imagery client applications.
Start your migration today to avoid disruptions in February 2026. If you have questions or need guidance, join the discussion in Esri Community or contact the Esri support team. Future-proof your workflows and make the most of your field photos with Oriented Imagery Layer!
