Export Orphaned Records from an iOS Device
2867
10-12-2023 05:11 PM
GlenShepherd
In the event that records to fail to send from your mobile device, we need a method for recovering and exporting them, so that they can be appended to the feature layer.
These are the steps for an iOS device
  • Install iTunes on your laptop
  • Connect the device to your laptop
  • Open iTunes, click on your device, and navigate to: File Sharing > Apps: QuickCapture > select the “ArcGIS” folder > 'Save' it to a local directory
  • Within that folder, locate a file with a ".qcr" (QuickCapture Recovery) extension.
  • Rename this file with a ".zip" extension, and then extract the data locally.
  • Within the unzipped folder, find the sqlite database containing the orphaned records.
For an Android device, the process is the same.  However we can use File Explorer instead of iTunes.
3 Comments
Contributors
About the Author
Esri Australia Client Success team member
