ArcGIS QuickCapture voice control: A step by step guide for iOS
3210
06-29-2021 01:33 PM
IsmaelChivite
Esri Notable Contributor
1 3 3,210
Imagine collecting data with QuickCapture without the need to look at or touch your phone? Using Apple's voice control features in iOs, you can operate ArcGIS QuickCapture with your voice.  Use voice commands to launch the app, open a project and to collect data!
This article describes how to configure Voice Control in your iOS device and a few tips to make your projects work best with Voice Control.
Configuring Voice Control in iOS
Voice Control is an operating system feature available in iOS 13. It allows you to use your voice to tap, swipe and type on your device.  Voice Control is not available in all countries or regions: it uses the Siri speech recognition engine for U.S. English only.
It's recommended that you connect to Wi-Fi before you turn on Voice Control for the first time. Before you can use Voice Control, a file download is required. Once the download is complete, you don't need a Wi-Fi connection to use Voice Control.
To configure your iOS device to use Voice Control:
  • Go to Settings
  • Tap on Accessibility
  • Tap on Voice Control
  • Turn on Voice control (A file download may be required at this moment)
  • Go back to the Home Screen
At the top-left corner of your phone, in the status bar, you will see a blue microphone icon indicating that Voice Control is actively listening to your commands. If the microphone icon is grayed out, say "Wake up" to activate Voice Control.
Now say, "Open QuickCapture" to launch the QuickCapture app.
To open a QuickCapture project from your the My Workspace page, say "Tap" followed by the name of your project.
To collect data, say "Tap" followed by the label of the button you want to tap.
Say "Go home" to return to the home page on your phone.
There are a handful of options to better control the behavior of Voice Control on iOS. You can find the details in the Use Voice Control on your iPhone, iPad, or iPod touch Apple article.
Tips to use Voice Control with ArcGIS QuickCapture
ArcGIS QuickCapture is not designed to be fully operated using voice commands, although it supports the most common actions:
  • To open ArcGIS QuickCapture, say "Open QuickCapture"
  • To launch a project from the My Workspace page, say "Open <project name>"
  • To push a button in your project, say "Tap <button label>"
  • To enter free text in project and button user inputs, use dictation
  • To tap Done or Skip when working with user inputs, say "Tap skip", or "Tap done"
These are the actions in ArcGIS QuickCapture that do not support Voice Control:
  • Sign out or sign in with a new account
  • Access the QuickCapture Settings, About  and Feedback dialogs
  • Interact with the camera: For example, you cannot press the shutter button, change the camera or activate/deactivate the flash
  • Interact with the map view: Open the map dialog, manually send records, change navigation mode or close the map page
If you want to enable unsupported actions, you can create custom Voice Commands
Here are a few additional tips:
  • If you plan to use voice commands with your QuickCapture project, use simple and short labels in all of your buttons. If a button does not have a label, you cannot invoke it with your voice (unless you use a custom command with a gesture).
  • Voice control can drain your battery more quickly. Be aware!
  • If you go to Accessibility - Voice Control - Customize Commands - Basic Navigation and turn <item name> on, then you do not need to say "Tap', before you specify the button to push.  Now, if you turn this on, then you will want to disable Text to speech in the QuickCapture settings and use either no sound or a beep. If you keep Text to speech activated in QuickCapture while the <item name> custom command is on, you will end up in an infinite loop! 🙂
3 Comments
PhillipGreville
Hi There,
I voice control in Quick Capture available for Android Devices?
JohnathanHasthorpe
Hi Philip,
This is an operating system capability that this is not currently supported by Android.
Thanks
John
OverhallaRoy
Occasional Explorer
I cant find the App Quick Capture on my AppleWatch. I would very much like to VoiceCommand my Phone from my Watch.. I have set up a project to capture every tree that I plant in the forest with QC, but it is not handy to have to use the phone, as I use both my hands for planting (and they get very vet and dirty). Can U add support for QC on AppleWatc ? Thanks.
Maybe AirPods will do the trick.. ??
Roy
