Landsat8Imagery in ArcGIS Pro
5079
9
10-30-2021 02:38 PM
KateEkhator74
I am having problems working with land sat8 imagery in ArcGIS Pro. I keep on getting this image (see attached) and I can't do my land classification with this. Please can any one help.
Thanks
JayantaPoddar
The Band Composite parameters look fine.
Do the individual bands display correctly in ArcGIS Pro?
If they do, then in the composite layer change the band combination to
For True Color Composite
Red Channel: Band 4
Green Channel: Band 3
Blue Channel: Band 2
For Standard False Color Composite
Red Channel: Band 5
Green Channel: Band 4
Blue Channel: Band 3
Think Location
DanPatterson
MVP Esteemed Contributor
Was this the original landsat image?
Did you add it to an empty map? (eg no topographic layer)
What are the image properties?
... sort of retired...
KateEkhator74
Yes it is the original landsat image, I ran the composite tool first and it automatically added it to the topographic map. I have attached a screenshot the properties.
JayantaPoddar
Do you have the individual band rasters? Landsat 8 band designations (usgs.gov)
What bands were used while creating the composite, and in what order?
Please share the screenshot of the parameters used in Composite Bands tool.
Think Location
KateEkhator74
Thanks for responding. I have attached a screenshot as requested. I made sure they were in order before running the composite band tool.
JayantaPoddar
Red Channel: Band 4
Red Channel: Band 5
Think Location
KateEkhator74
Thanks.
DanPatterson
If it is the original landsat image, it would already be composite bands.
Why would you run the tool if it already had 3 or more bands? (it has 7 bands now)
Composite Bands (Data Management)—ArcGIS Pro | Documentation
Is this the original image?  not the one with composite bands run on it.
KateEkhator74
Landsat8 images comes as individual bands. See attached screenshot.
DanPatterson
ahhhh no wonder it looks strange to me
Landsat 8 bands 4, 3, and 2 correspond to the red, green, and blue portions of the visible spectrum.
Elegant Figures - How To Make a True-Color Landsat 8 Image (nasa.gov)
Landsat 8 – Natural color (shadedrelief.com)
