Help me calculate field records with small python code
2233
09-14-2023 06:03 AM
shotatskhovrebashvili
I have a python code that works for a single record:
from datetime import datetime, timedelta
utc = datetime(1980, 1, 6) + timedelta(seconds=1325841623 - (35 - 17))
print(utc)
Result: 2022-01-10 09:20:05
How can I modify the code so it can calculate each record in the field by that formula?
Tags (1)
EarlMedina
Okay, so all you have to do is pop open your Field Calculator, write a simple function, and apply to your target date field like so:
With your sample values, I get:
EarlMedina
What's the input/value that changes across the records? Is it the date (1980, 1, 6)?
The input values are GPS seconds, like: 1325841623 and after using the formula you get the date in UTC: 2022-01-10 09:20:05
I have thousands of records to be converted. Here are few examples:
1325841623; 1325841625; 1325841626; 1325841627; 1325841628; 1325841629; 1325841630;
EarlMedina
Thank you so much 😍
