Help me calculate field records with small python code
2229
5
09-14-2023 06:03 AM
Labels (3)
shotatskhovrebashvili
I have a python code that works for a single record:
from datetime import datetime, timedelta
utc = datetime(1980, 1, 6) + timedelta(seconds=1325841623 - (35 - 17))
print(utc)
Result: 2022-01-10 09:20:05
How can I modify the code so it can calculate each record in the field by that formula?
EarlMedina
Okay, so all you have to do is pop open your Field Calculator, write a simple function, and apply to your target date field like so:
With your sample values, I get:
EarlMedina
What's the input/value that changes across the records? Is it the date (1980, 1, 6)?
The input values are GPS seconds, like: 1325841623 and after using the formula you get the date in UTC: 2022-01-10 09:20:05
I have thousands of records to be converted. Here are few examples:
1325841623; 1325841625; 1325841626; 1325841627; 1325841628; 1325841629; 1325841630;
EarlMedina
Thank you so much 😍
