Cannot modify features (Editing) in ArcGIS Pro 2.8.3
4174
10-21-2021 12:00 PM
stalinsulbaran1
Hi, I am having an issue trying to modify features (editing) in ArcGIS Pro 2.8.3. I have checked with a co-worker who also uses version 2.8.3 and It works good, I am the only one with the issue.
ArcGIS Pro let me create features without problem, However, when I am trying to Move, Rotate or Scale, It doesn't let me select any feature.
Any idea you could give I really appreciated, best regards!
stalinsulbaran1
It is a feature class in a geodatabase. However, searching in a old post I find the answer, It was in the selection tab - combination mode (for no reason it has changed to Remove from current selection). I just changed to create a new selection and It works.
Here is the link of the old post: https://community.esri.com/t5/arcgis-pro-questions/solved-arcpro-unable-to-select-feature-with/td-p/...
Thank you very much for your answers!
KoryKramer
Esri Esteemed Contributor
Have you checked to make sure that they layer is selectable and editable?
stalinsulbaran1
Yes, both selectable and editable. It happens with all features from my projects (old and new).
ABishop
@stalinsulbaran1
What type of feature is it?  Is it a feature class in a database or a feature service?
Amanda Bishop, GISP
stalinsulbaran1
