Unable to add Shapefile in zipped format
15606
34
12-16-2011 12:51 AM
FaisalAziz
I am trying to add a point theme shapefile after compressed it into a zip format in Map viewer but everytime it gives an error "Unable to import this shapefile". if I add the file in csv format then it gives an error "File does not seem to contain fields with point coordinates".
KnudsonLp
I have the same problem. When I upload the zipped shapefile to the online map through our organization account, I keep getting the error 'unable to import the shapefile'. There is no subfolder in the zip file.
StephanieFaulkner
i'm in same position with not adding the Oregon state highways
https://spatialdata.oregonexplorer.info/geoportal/details;id=6bed1138c1db44b0828e31a4d469ab81
KellyGerrow
Esri Alum
I just downloaded and uploaded this layer. The data mentioned by Stephanie is a File Geodatabase and not a shape file. That being said, I couldn't publish this as a File Geodatabase either. Could you get a support case created to look into this specific dataset?
Kelly
StephanieFaulkner
Kelly, thanks. I realized it was a geodatabase shape file after the
post. I think I can get this data another way by exporting the highway
file from a Spatial apps MOOC. Would that subset work for you? I
eventually need the entire Oregon DOT layer. Let me work on this...let's
stay in touch
Stephanie
KellyGerrow
Esri Alum
HI Stephanie,
I gave this another test in incognito mode and it looks like I was running into a browser bug, outlined in this blog:
https://community.esri.com/people/ARex-esristaff/blog/2019/03/12/why-cant-i-use-the-add-item-dialog-...
Here is an example of the published FGDB.
http://arcg.is/0yq8KD
If you are using chrome, try using another browser or open it in incognito mode.
Let me know if changing up the browser works. A fix should be out in an upcoming release of chrome.
-Kelly
