Unable to add Shapefile in zipped format
15744
34
12-16-2011 12:51 AM
FaisalAziz
I am trying to add a point theme shapefile after compressed it into a zip format in Map viewer but everytime it gives an error "Unable to import this shapefile". if I add the file in csv format then it gives an error "File does not seem to contain fields with point coordinates".
JamesLabate
Jim,
Can you share your file here so we can try it out?
Mike
Mike,
Better late than never - shortly after posting i realized I'd been reflexively zipping all files into an auto-generated folder (as many of us seem naturally to do while sleepwalking through using the winzip tool). Once the shp was zipped in the root it uploaded fine.
Appreciate the response,
Jim
JoshCoefer2
I am suddenly having a similar issue - getting the "Unable to add Shapefile" error when uploading the zip file.  The strange thing is that I was able to upload these same shapefiles yesterday with no issues.  I have uploaded shapefiles as .zip to arcgis.com many times in the past and have never had this problem.  There are only a few hundred records...
MikeMinami
Esri Notable Contributor
Yes, we are currently experiencing problems adding shapefiles to web maps. it's not working. We hope to have this resolved shortly.
Mike
AustinRidgely
I have been tring to upload files this afternoon for a presentation tomorrow please and have too been getting the unable to load file.  Please post when the problem is fixed.
LucasDanzinger
Esri Frequent Contributor
Austin, this issue should be resolved now.
SidneyNovoa
I have the same problem when I tried to load my shapefiles. I'm sharing the file in case someone can help me.
KellyGerrow
Esri Alum
What browser are you using?
I am able to successfully add your Shapefile to the Map Viewer.
http://bit.ly/1h1cxe6
Kelly
andreaseleftheriou
I am cannot upload this zip file.
AmeliaNewsam
I am also unable to upload a zipped shapefile.  I have no extra folders that I can see.  I don't see now to attach the files here.
KellyGerrow
Esri Alum
Try uploading the shapefile to ArcGIS Online without publishing it as a hosted feature service. Then share the item with everyone and share the link with this post.
