Unable to add Shapefile in zipped format
15723
34
12-16-2011 12:51 AM
FaisalAziz
I am trying to add a point theme shapefile after compressed it into a zip format in Map viewer but everytime it gives an error "Unable to import this shapefile". if I add the file in csv format then it gives an error "File does not seem to contain fields with point coordinates".
MikeMinami
Esri Notable Contributor
There may be a problem with your zipped shapefile. Have you included all the necessary files in the zipped file? Shapefiles have many auxiliary files. Also, to import a CSV, you need to have the x,y locations of the points in the file as well. We look for field names like lat, long, x, y...
If these don't help, upload your zip file here and we can take a look at it.
Mike
JamesLabate
Fazkan and Mike,
I'm having the same problem adding a simple zipped point file. It's a shp with about 100 features. I've zipped all the files: dbf, sbx. sbn, prj etc and also tried with just shp, sbx, dbf, prj. Same "unable to import" error both times. I use the old winzip format .zip not zipx.
The shp file was merged and exported out of file GDB feature classes. Does that matter?
Jim
MikeMinami
Jim,
Can you share your file here so we can try it out?
Mike
ChrisBowles
Hi There,
I'm having a similar problem to those above.  I've attached a zipped sample of the points shapefiles I'm trying to upload.  Also using Winzip.  I've successfully loaded polygon shapefiles in this way, so I don't think there's an issue with my configuration.  Any help is greatly appreciated.
Chris
MikeMinami
Chris,
Your shapfile is missing its prj file.
Mike
Stefanvan_der_Hoorn
Hi there,
I am also having a similar problem. I keep receiving the error: unable to import the shapefile.
I have tried various zipped shapefiles. I have adjusted the number of rows (which was more than 1000), to less then 1000.
I tried point, lines and polygins, but none is working.
Attached you find a zipped file with points.
Hope someone can help me.
Kind regards,
Stefan
ChrisBowles
Ah...so it is.  Thanks Mike.
Jim,
Mike
MikeMinami
Stefan
The error message I can see is
"The operation was attempted on an empty geometry."
is it possible that the geometry for one of the features is bad? However, I am able to open this shapefile in ArcMap. We'll have to take a closer look.
Mike
MikeMinami
Stefan,
It seems like the coordinates in the shapefile don't match the expected coordinates of the spatial reference as defined in the PRJ file.
When I open this shapefile in ArcGIS Desktop, I get an error "One or more layers has an extent that is not consistent with the associated spatial reference information.
In looking at the coordinates inside the shapefile, here's a sample:
[92062.2500000003, 436080.33999999997] , [92063.75000000001, 436080.33999999997] , [92063.75000000001, 436078.84000000026]
This is the spatial reference in the PRJ file
http://spatialreference.org/ref/epsg/4326/
Coordinate values should be between -180.0000, -90.0000, 180.0000, 90.0000
Mike
