Popup line height in the new mapviewer
2272
8
09-16-2021 07:51 AM
MichelleHawks1
New Contributor II
Hello.   I am trying to format a popup in the new mapviewer and can't find a way to control the spacing between the lines.  I am using arcade expressions in my popup.  When I write all of the lines into one expression, the spacing is perfect, but when I use multiple lines, it is too spread out.  I want to use multiple lines because I need some color formatting based on conditional outputs.  I've included a screenshot that shows both situations, and one with the popup text box.  The {expression0} at the bottom is the composite list of all lines at the bottom of the popup pic.  If anyone has any ideas, I would be very grateful.
mdonnelly
Hello Michelle,
Have you considered using the Custom Attribute Display option when creating your popup?
When you are configuring your pop up, from the display drop down, select 'a custom attribute display', then Configure.
This will present you with a dialog that allows you to have finer control over how your popup is formatted.
You can even choose the HTML option if you want even finer control.
Regards,
Mark
MichelleHawks1
New Contributor II
Hello.  Thank you for responding.  That is the method I used in Map Viewer Classic, but in the new Map Viewer I can't figure out how to do that same thing.
AnthonyJonesRSK
Occasional Contributor II
I'd like to know if there is a way to change the line spacing too. For some reason when adding a text element to the pop up the default leaves large gaps between each line as Michelle has demonstrated. Is there anyway to change this?
I assume it could be avoided by generating the whole pop up using arcade but this seems a bit impractical if all you want is a few lines of text. Thanks
AntoinevanEsch
There is an easy way to remove the spacing. Go to the HTML section in the text pop up. Remove for example the highlighted area as you can see below and add <br> between the parts. Now the spacing is removed.
Hope this will help 🙂
AllisonWebb
New Contributor II
How do you save the HTML section once you add the <br>.  The OK is greyed out.
AllisonWebb
New Contributor II
I just had to close it...  🙂
LauraGonzalezMantecon
AprilPearce1
you don't click 'ok' you click on the 'source' button you used to get to the html - it took me a minute
