Can't view "Related Records" option using a webservice
2151
24
11-02-2023 12:13 PM
BrianBulla
Regular Contributor II
I'm trying to show related records in a pop-up.  According to this blog ( https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/rolling-out-related-records-in-map... ) article, I should be able to do this, but for some reason I do not have the option to "Add Content - Related Records".  See screenshot below.  Can anyone explain what might be going wrong here??
Here are the details on the webservice I am using.  I can view the features, and modify the features fields in the pop-up.  Just no access to the related table for some reason.
ArcGIS REST Services DirectoryLogin | Get Token
Home > services > Works > Valves_Over_Inspections (MapServer)Help | API Reference
JSON | SOAP
Works/Valves_Over_Inspections (MapServer)
View In:   ArcGIS JavaScript   ArcGIS Online Map Viewer   ArcGIS Earth   ArcMap   ArcGIS Pro
View Footprint In:   ArcGIS Online Map Viewer
Service Description:
Map Name: Valves Over Inspections
Legend
All Layers and Tables
Dynamic Legend
Dynamic All Layers
Layers:Tables:Description:
Copyright Text:
Spatial Reference: 26917  (26917)
Single Fused Map Cache: false
Initial Extent:
      XMin: 670900.4892873524
      YMin: 4861540.759367962
      XMax: 671264.1504525405
      YMax: 4861797.333926209
Full Extent:
      XMin: 632250.5783000002
      YMin: 4845167.040200001
      XMax: 706521.8962000003
      YMax: 4932435.0529
Units: esriMeters
Supported Image Format Types: PNG32,PNG24,PNG,JPG,DIB,TIFF,EMF,PS,PDF,GIF,SVG,SVGZ,BMP
Document Info:
      Title: Map
      Author:
      Comments:
      Subject:
      Category:
      Keywords:
      AntialiasingMode: Fast
      TextAntialiasingMode: Force
Supports Dynamic Layers: true
MaxRecordCount: 2000
MaxImageHeight: 4096
MaxImageWidth: 4096
Supported Query Formats: JSON, geoJSON, PBF
Supports Query Data Elements: true
Min Scale: 0
Max Scale: 0
Supports Datum Transformation: true
Child Resources:   Info   Dynamic Layer
Supported Operations:   Export Map   Identify   QueryDomains   QueryLegends   Find   Return Updates
KenBuja
Do you have a relationship set up with that specific layer? If you click on the "Valves Over Inspected" layer, does that page contain a list of relationships? For example, this layer has several relationships set up.
BrianBulla
Yes, both the Valves Over and the Valves Under have a related table:
ArmstKP
@BrianBulla @KenBuja  Related records from ArcGIS Server services are still not supported in the map viewer, surprisingly and unbelievably!  You still have to use the classic map viewer to do so.
KenBuja
I can view related records in a popup using the Map Viewer. For example, using the service in my previous message, I built a popup to show the information from a related table.
var rec = First(FeatureSetByRelationshipName($feature, "DCGIS.ITSPE", ['BIDNAME', 'BIDTOTALDUE', 'BIDCOLLECTED', 'BIDBALANCE']));
if (IsEmpty(rec.BIDNAME)) return 'Not a BID';
return `${rec.BIDNAME}
    • Total Due: ${Text(rec.BIDTOTALDUE, '$#,###.00')}
    • Collected: ${Text(rec.BIDCOLLECTED, '$#,###.00')}
    • Balance: ${Text(rec.BIDBALANCE, '$#,###.00')}`
ArmstKP
@KenBuja Sure, you have to use arcade expressions to do so, but then the related records aren't interactive like they are with hosted feature layers (below):
BrianBulla
Hi Ken,
Just troublehsooting this now, and even the Arcade is not working.  So with your example, when you're in the AGOL webmap and you click on "Tables" on the left hand side, do you see all of your related tables available?  In mine I see nothing.  But maybe related tables don't show up here anyways....I'm just curious.
by Anonymous User
Not applicable
BrianBulla
Yes, this is what I experience too.
KenBuja
You can add a related table to your map, using the Add button in the upper left and using the URL of your table layer.
