Arcade FeatureSets and Date Fields: What's Going On?
3253
02-24-2022 02:59 PM
jcarlson
When creating a FeatureSet from a dictionary, as in Data Expressions in Dashboards, I cannot add a date to a date field.
In the simplest example, here's a single-feature set with a single field, which ought to have the current date/time in it.
var fs_dict = {
    fields: [{name: 'some_date', type: 'esriFieldTypeDate'}],
    geometryType: '',
    features: [
        {attributes: {some_date: Now()}}
return FeatureSet(Text(fs_dict))
However, this returns an empty set.
Casting the date as a number, however, seems to work. Replace line 5 with the following:
{attributes: {some_date: Number(Now())}}
And it returns my feature!
I thought perhaps this was due to a difference in how the text-encoded datetime was being read. Leaving it as the datetime gives me 2022-02-24T22:48:57.371Z, whereas the number returns 1645742863932.
But cast either of those as a date, and it reads them both in just fine:
So what's going on in the FeatureSet function? Why can it not handle text dates?
To add another layer to this, I can't even take a feature from one set and pass it to another without losing the rows with dates.
var fs_dict = {
    geometryType: '',
    features: [
        {attributes: {some_date: Now()}},
        {attributes: {some_date: Null}}
var fs = FeatureSet(Text(fs_dict))
var second_dict = {
    geometryType: '',
    features: []
// Copy features from fs to dict
for (var f in fs){
    Push(second_dict['features'], f)
return FeatureSet(Text(second_dict))
Returns a one-row set with the null value, but not the Now.
The only way to pass features between sets is to cast them as a Number, but I can only do that by explicitly stating each attribute, rather than just passing the entire feature.
- Josh Carlson
Kendall County GIS
DavidNyenhuis1
With this week's update to Arcade and ArcGIS Dashboards, date fields in feature set constructors now just work. You no longer have to wrap dates with Number() if you pass the dictionary into the FeatureSet() function (which as of this release accepts a dictionary as opposed to only text based JSON).
Instead of:
return FeatureSet(Text(dict))
Do this:
return FeatureSet(dict)
Learn more in this blog post
NOTE: For Enterprise users, this update is targeted for 11.2
XanderBakker
Esri Esteemed Contributor
Hi @jcarlson ,
There is something additional you need to do in order to create a valid featureset containing dates. The date has to be translated to a UNIX timestamp.  In the post below you can see an example: https://community.esri.com/t5/developers-questions/arcade-dictionary-to-featureset/td-p/1047117
DavidNyenhuis1
Instead of:
Do this:
