Testing ArcGIS for Javacript React components using Jest
19074
34
07-09-2021 07:42 AM
craragon77
Hello all,
I'm encountering a weird error when I try to use Jest to test my react components which contain ArcGIS maps. I'm attempting to make a simple smoke screen test for a component which contain an ArcGIS map, but I always get this error from Jest saying "Jest encountered an unexpected token", meaning that Jest cannot read it. This error appears in every component with the arcGIS map in its ancestry. For example, I am getting an instance of the error from the App component because it's importing a child component which itself hosts an arcGIS map. I understand that ArcGIS uses Intern for its testing, but I'm not trying to test the source code, just the React components (which I wrote) where the ArcGIS maps live. I am using React 17.0.1, and I am using the @arcgis/core package (version 14.8.1) to make the maps. Can I get a second set of eyes on this? It's really T-Boning my tests 😕
Tags (3)
AndyGup
@MatthieuBrissetcan you provide a simple github repo? That will be the easiest way to troubleshoot.
cc @Anonymous User
EmreCan
I face the same problem with version 4.21 and Angular 12.
AndyGup
@EmreCanhere's an example for Angular 11 + Jest: https://github.com/andygup/angular-jsapi-jest
EmreCan
@AndyGup  I cloned the repo and tried again but I'm getting the same error "Cannot use import statement outside a module".
Can u please test it again?
AndyGup
@EmreCan @MatthieuBrisset Ah yes, I blew away my old node_modules and package-lock. When I reinstalled I see the problem, a dependency update changed something and I'm not sure why it doesn't work now. It will take some time to research. Hopefully it's just a configuration issue.
MatthieuBrisset
Hello @AndyGup
Thank you for your answer.
Here is a minimal application with our full Webpack and Jest config and which reproduces the error.
https://github.com/mattoche/arcgis-unit-testing
AndyGup
@MatthieuBrisset  your repo doesn't seem to have jest.config.js and babel.config.js? There are also a bunch of dependencies in there that may/may-not affect something. One recommendation is use one of our repos as a starting point because they have minimal dependencies: https://github.com/Esri/jsapi-resources/tree/master/esm-samples.
MatthieuBrisset
@AndyGupThe babel and jest configuration are embedded in the package.json (search for tag "babel" and "jest")
This repo https://github.com/Esri/jsapi-resources/tree/master/esm-samples/webpack has been used to initialize the projet but we add bunch of dependencies since (linter, prettier, minifier, etc)
defiantgoat
This worked for me in my jest.config.js:
  "transform": {
    "^.+\\.(js|jsx|ts|tsx)?$": "ts-jest"
  "transformIgnorePatterns": [
    "node_modules/(?!(@arcgis|@esri|@stencil)/)"
I also added allowJS: true to my tsconfig file and just allowed ts-jest to transform everything rather than adding babel in.
This is the sample codebase > https://github.com/defiantgoat/esri-react-typescript
MatthieuBrisset
Thanks !!!
It works as expected by adding allowJS : true.
