show domain in dgrid/OnDemandGrid
6387
11
07-15-2015 10:04 AM
AuraRamos_Lora1
Could you help me, please to show domain in dgrid, this is functionally in infowindow but in grid puts the code,  not the description.of domain.
var outFieldsProy = ["PROYECTO", "NOMBRE", "ESC250", "AERONAVE"]
var gridProy = new (declare([Grid, Selection,ColumnHider, ColumnReorder, ColumnResizer]))({
      bufferRows : Infinity,
      columns : {
        PROYECTO : "Proyecto",
        NOMBRE : "Nombre",
        ESC250 : "Escala 250",
        AERONAVE : "Aeronave"
    }, "divGrid");
function populateGrid(results) {
            // var gridData;
            dataQuakes = arrayUtils.map(results.features, function (feature) {
                return {
                    "PROYECTO": feature.attributes[outFieldsProy[0]],
                    "NOMBRE": feature.attributes[outFieldsProy[1]],
                    "ESC250": feature.attributes[outFieldsProy[2]],
                    "AERONAVE": feature.attributes[outFieldsProy[3]]
            var memStore = new Memory({
                data: dataQuakes
            gridProy.set("store", memStore)
Thanks
thejuskambi
you should find something here QueryTask and coded domain values
AuraRamos_Lora1
Thank you thejus kambi
This function  _getCodedValue: function (layer, fieldName, fieldValue, typeID)       must be before this?:
            // var gridData;
                return {
and other question,  ¿which is typeID?
Regards
thejuskambi
Ignore that as you might not have it. It is to be use when you have a subtypes in FeatureLayer.
You can use the fields property of the query result. Select the field which has domain.
var field = results.fields["< field name  >"]
var codedValueDomain = field.domain;
and use this domain and get the code value, while looping through the features and prepare the data for grid.
AuraRamos_Lora1
I´m sorry, but I have other question.
My query result is a featureset. how can I convert this to fields type?
//Inicializa el query
            var queryProy = new Query();
            queryProy.geometry = geometryInput;
            //Wire the layer's selection complete event
            operationsPolygonLayer.on("selection-complete", populateGrid);
            // Transforma la selección
            operationsPolygonLayer.selectFeatures(queryProy, FeatureLayer.SELECTION_NEW);
because
var field = results.fields["AERONAVE"];
is undefined
Thanks again
Regards
thejuskambi
I thought you are using QueryTask to get the results. Now I see you are using featureLayer. The FeatureLayer has fields property use that instead.
RickeyFight
I am having a hard time getting coded domains to show up.
What part of the code did you put this into:
var field = feature.fields["<Priority>"]
I am using this template
DataGrid with zoom button | ArcGIS API for JavaScript
thejuskambi
Hello Rickey,
You need to do if before you set the data to dgrid. like below
statesLayer.on("load", function(evt) {
          var query = new Query();
          query.where = "1=1";
          evt.layer.queryFeatures(query, function(featureSet) {
            var items = array.map(featureSet.features, function(feature) {
                   var attributes = lang.clone(feature.attributes);
                   var fields = statesLayer.fields;
                   //Replace the attributes values for domain values here.
                   return attributes;
            //idProperty must be set manually if value is something other than 'id'
              data: items,
              idProperty: "ObjectID"
            window.grid.set("store", memStore);
            window.grid.set("sort", "STATE_NAME");
            grid.on(".field-ObjectID:click", function(e) {
              //retrieve the ObjectId when someone clicks on the magnifying glass
              if (e.target.alt) {
                zoomRow(e.target.alt);
Thejus
RickeyFight
I get an error of:
Cannot read property '<Priority>' of undefined
where priority is my field name
thejuskambi
you should try without the "<" ">" signs. also feature does not contain the fields property. if you see my code, I am getting the fields from the stateLayer and not feature.
