I want to show all features which are in cluster in list in arcgis api 3.4
1034
08-05-2022 06:34 AM
ZeeshanRabbani
Hi
I want to show all features which are in current cluster in list inside the popup in 3.4, i want same popup of list as we get in arcgis api 4.24.
I have used hitTest() it is not working,
problem is i cannot get the features which are in the cluster on which I click(current cluster).
ReneRubalcava
Esri Frequent Contributor
In 3x, if a Graphic is aggregate, a cluster graphic, it has a method called getChildGraphics you can. use.
https://developers.arcgis.com/javascript/3/jsapi/graphic-amd.html#getchildgraphics
I have an old blog post from 2017 that might still be useful for 3x here.
https://odoe.net/blog/interactive-clusters-arcgis-api-javascript
ZeeshanRabbani
Hi thankyou but this blog show same example as api sample shows
The yellow highlighted next and previous button i dont need this I need to show all at a time in a list.
LIKE THIS
Problem Im having is i cant get the items or features which are in current cluster(on which i click)
