Content Pane & Button Placements?
8424
11
05-18-2016 08:46 AM
NMWater
Hi all!
I'm having a bit of trouble getting my home button to align correctly inside a content pane. I'm trying to place it under the zoom in/ zoom out button.  Below is my CSS and my style. I tried placing it under my map div but that didn't work. Any suggestions?
Body:
CSS:
RESULTS:
KenBuja
MVP Esteemed Contributor
Have you seen this sample?
Home Button | ArcGIS API for JavaScript
RobertScheitlin__GISP
Francisco,
  This seems to work fine for me (I built an app based on the code you show):
<!DOCTYPE HTML>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Home Extent</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
  <style>
    html, body, #map {
      padding:0;
      margin:0;
      height:100%;
    #HomeButton {
      display: block;
      position: absolute;
      top: 90px;
      left: 20px;
      z-index: 2;
  </style>
  <script src="//js.arcgis.com/3.16/"></script>
  <script>
    require([
      "esri/map",
      "esri/dijit/HomeButton",
      "dojo/parser",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane",
      "dojo/domReady!"
    ], function(
      Map, HomeButton, parser
      parser.parse();
      var map = new Map("map", {
        center: [-56.049, 38.485],
        zoom: 3,
        basemap: "streets"
      var home = new HomeButton({
        map: map
      }, "HomeButton");
      home.startup();
  </script>
</head>
<body class="claro esri">
  <div data-dojo-type="dijit/layout/BoarderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%">
    <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center', splitter:true" style="height:50%">
      <div id="map" class="map">
        <div id="HomeButton"></div>
      </div>
    </div>
    <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom', splitter:true" style="height:50%">
      <div id="TesTable"></div>
    </div>
  </div>
</body>
</html>
