Allow zoom above max level of details ?
5102
11
04-15-2022 05:57 AM
devmap125
Hi ESRI community,
I have a simple problem I believe,  in a basic map setup, I can add a layer like this
map = new Map({basemap: "topo-vector" });
new MapView({ map: map,....});
map.add(new ImageryTileLayer({url:".../Terrain3D/ImageServer"}));
but when I zoom too much in the layers disapears,
my question:
how can I force the display of last available Level Of detail ? to be clear, I don't want to limit the mapzoom to the max layer's LOD, I want to zoom as much as possible even if pixelated
in advance for your help a big thx !
MarkW
by Esri Contributor
Hello,
You should be able to update the max and min scale so that the layer does not disappear at different levels of zoom. Here is the documentaion: https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-ImageryTileLayer.html#maxS....
I hope this helps.
Mark W
devmap125
hello thank you for yuour answer but I have been through that already,
, as you can read in the link you mention ,
maxScale:  If the map is zoomed in beyond this scale, the layer will not be visible
if you have other suggestionI'm still looking
MarkW
by Esri Contributor
Oh ok, do you mind sharing your layer so I can do some troubleshooting with it?
Thanks
Mark W
devmap126
yes of course, it's this one :
https://elevation3d.arcgis.com/arcgis/rest/services/WorldElevation3D/Terrain3D/ImageServer
I use it in combination with a RasterShadedReliefRenderer to colorize the map elevation with the colorRamp
It works like a charm from a far, but it's very frustrating when I zoom too much in I loose the colored layer, I made this tool to find new spots to pratice my sport, but from so far it's useless sadly ...
With https://elevation3d.arcgis.com/arcgis/rest/services/Elevation/World_Hillshade/MapServer (TileLayer)  I can zoom how much I want ... but not use RasterShadedReliefRenderer  and ColorRamps
devmap126
any one ? 🙂 @MarkW
MarkW
by Esri Contributor
Unfortunately this appears to be a bug right now, I have reported it so hopefully it gets addressed soon. Sorry for the inconvenience. I will let you know if I discover anything else.
Mark W
devmap126
@MarkW Oh shout ! I've been battling with this for a while, I even had posted an other question few month ago about it with no answer. Any idea If I can reverse engeneer the JS and just trig an event to un hide the layer from the console manualy ?
UndralBatsukh
Hi there,
This is not a bug! The API working as designed. ImageryTilelayer does a raster level overzoom not a tile based over zooms. It will over zoom the data from the last available LOD. There is no data for areas such as Tibet at the last available LOD. So when we over zoom, we don't show data since there is no data available at the last available LOD. We can add a boolean flag to resample tiles from its last available LOD. However, in this case the result will be incorrect completely.
-Undral
MarkW
by Esri Contributor
Oh ok, thank you for letting us know! So it is simply working as designed.
Mark W
