Open search box by default - My Government Services
4519
7
11-25-2015 02:13 PM
AllenScully
Looking for the setting in either html code or js code to have the address search box open by default.  Fairly new to customizing these apps, so I'm guessing this a pretty simple setting if you know where to look.
Alternately, something like the initial map view here would be ideal (probably requires more involved configuration):
LuciHawkins
Hi Rickey,
In an older version of My Government Services, ESRI has the following code which would be around Line 73 in the new version of default.htm
div style="width: 75px; margin-top: 7px;" class="customButton" onclick="HideSplashScreenMessage(); ShowLocateContainer();">
It calls the "ShowLocateContainer" function from Utils.js after someone closes the splash screen. I am not sure if the new version has that function in the Utils.js or not.  If it does not, I can post that function also.
Luci
RickeyFight
MVP Regular Contributor
Allen,
What version of the app are you using?
Are you using this one:
http://tryitlive.arcgis.com/MyGovernmentServices/
AllenScully
Hi Rickey -
Thanks for the quick response.
Yes - that's the version we are using - is there an older one that is already configured like the screen shot?
We have our own geocoder hooked up, but we're replacing an old flex based app that had the search address open when the map was opened.
RickeyFight
Allen,
I would imagine that it is possible.  I have not found a way to do it yet.
RickeyFight
Allen,
Luci Hawkins got it to work with Fort Walton Beach here:
Park and Rec finder Activity automatically selected
Loading...
I know that the links are to parks and rec but the search tools are very similar. I would maybe ask a question and see if she will share how it was done.
LuciHawkins
Hi Rickey,
Luci
AllenScully
Hi Luci and Rickey -
Yes indeed the Utils.js file still has the ShowLocateContainer, and adding it as Luci references like the older version works perfectly.
Really appreciate your looking into this - still getting my feet wet with custom java script, so this is quite helpful.
Thanks
Allen
LuciHawkins
Glad we could help and it is working for you
