ArcGIS Indoors Blog
127
34.5K
43
Open | It would be nice to have a geoprocessing tool that functions just like the "Update Occupant Features" tool, but the t... by mshanaghan Frequent Contributor 1 0 | 1 | 0 | |
Open | It would be very beneficial to be able to rearrange the order of the filter options within the Space Planner app. It ... by MollyE Occasional Contributor 0 3 | 0 | 3 | |
Open | Adding support for annotations in Indoors making them floor aware would be of good use for us running large venues/ca... by PatrikStröm Emerging Contributor 0 0 | 0 | 0 | |
Open | ArcGIS Indoors View 360 include a caption and or pop up to explain what is in the image, by GiovanniZambotti Occasional Contributor 0 0 | 0 | 0 | |
Open | We have 46 ipad kiosks with ArcGIS Indoors viewer deployed around 11 campuses. Not all are facing north. We would l... by HBWiese Occasional Contributor 2 0 | 2 | 0 | |
Open | There is a blue outline of our facilities in the viewer, even though the facilities are set to invisible. It's really... by LeviCecil Frequent Contributor 1 3 | 1 | 3 | |
Open | In our Indoor Viewer when someone enters a search code (for example "1234") in the search bar and immediately hits th... by HBWiese Occasional Contributor 2 1 | 2 | 1 | |
Open | It would be extremely helpful to have the search widget in the Floor Plan Editor web app. My organization uses Floor ... by MelissaSalich Frequent Contributor 4 0 | 4 | 0 | |
Open | It would be helpful to be able to configure content in Space Planner through the web map.Use Case: We want to be able... by AndrewBowne Frequent Contributor 4 0 | 4 | 0 | |
Open | When reserving a workspace with the Indoor Viewer using the Indoors Reservation layer, it would be nice to have the t... by MelissaSalich Frequent Contributor 3 1 | 3 | 1 | |
Open | Allow a URL parameter in the Indoor/Kiosk Viewer App that can set the "Home" location of the kiosk based on a layer i... by KevinDohner Occasional Contributor 5 0 | 5 | 0 | |
Open | Currently, when using floor-aware data/maps, you filter by selecting a facility then a level. That filter only appli... by ChristopherJStrong Occasional Contributor 11 3 | 11 | 3 | |
Open | Having a Indoors App of the UC venue has been fantastic. Thank you so much for doing this and implenting my idea. It ... by COSPNWGuy Frequent Contributor 0 0 | 0 | 0 | |
Open | In the configuration settings of the Indoors Viewer, add Splash Screen option to configure for instructions/user info... by MelissaSalich Frequent Contributor 12 0 | 12 | 0 | |
Open | As part of my indoors import automation I would like to add definition queries to the BIM to reduce data added to the... by Treavon Regular Contributor 2 1 | 2 | 1 |
Idea Submission Guidelines
