Route not found - report to administrator enhancements
In the ArcGIS Indoors mobile app, could the Route not Found report automatically include the user's origin and destination? Coordinates would also be helpful if the user dropped a pin. It would be even better if selecting "Report" could open a survey123 or something that could notify the admin more directly. 😁
Indoors Levels suddenly stopped filtering with floor filter widget
Hello, We have indoors in Portal v. 11.2 and I noticed that the Levels stopped responding to the building filter in our maps app etc. The units, details, site, & facilities still filter as expected. I don't know how long this has been an issue - but it wasn't always an issue. This is happening on all buildings with…
Why is Import Floorplans to Indoors GDB being Deprecated?
As the title states, I am confused as to why the Import Floorplans to Indoors GDB is being deprecated in favor of Import CAD To Indoor Dataset. Despite the message above from Esri, the Import CAD to Indoor Dataset in fact does not replace the functionality of the Import Floorplans tool. It breaks down an import process…
Change Symbology of Levels and Facilities Related Items in Indoor Viewer
In the Indoors Viewer, how do you change the symbology of the Related Items? Specifically the Levels and Facilities, the default is an orange circle. The Related Items takes the symbology from the Configured Categories, but if I don't have any configured categories for Levels or Facilities, how do I change from the orange…
360 Video to Oriented Imagery outside OID Domain
I've been testing 360 Video to Oriented Imagery in ArcGIS Pro 3.7.2 in our development environment and have been running into a Domain outside OID bounds. Has anyone else been experiencing this issue and has a fix for it? I'm currently working in MGA2020 zone 55 and the coordinates of the georeferencing points are within…
Space Planner Restricting Assigning Units based on Organizational Areas
We are looking at using Space Planner as a way to have departments plan where their staff will be sitting in our new building, which will house about 10 different departments across 17 floors. I have allocated units to the different departments by defining organizational areas. There will be managers from each department…
Indoors Viewer should honour filters on Events-layer in Web Maps
Currently, the filters defined in a web map on the Events-layer are not honoured in the Indoors Viewer app. We have a couple of events that are not of public interest, and should not show up in the Viewer. So I defined a filter in my web map to only show the relevant events, nevertheless they still appear in the…
Reservation Indoors Viewer App Not Keeping WebMap Filters
I have set up a few facilities to be compatible with the Reservation app. I set up queries to facilities, sites, levels, units, and details for these facilities. Every other building in the county is filtered out. I have set up all those queries in the web map that is tied to the app. The app itself does not respect the…
ArcGIS Indoors – visualize 3D stacked polygons
I have a project requiring me to map equipment housed in vertical racks and display "open" spaces for equipment. I am attempting to use the Units 3D field to represent the individual space and stack the Units. I am working through how to use the elevation properties setting or the extrusion tool to stack them. Has anyone…
Floor Plan Editor Customisation and License Requirements
Hello, Does anyone know the following: 1. Which license are a must-have to have floor plan editor in a 11.3 ArcGIS Enterprise base build. 2. Is Indoor viewer, which requires a Network Analyst extension, mandatory? 3. Is it possible to customise the UI and add bespoke widgets and rules to the Floor Plan Editor? Thanks,…
Indoor Floor Plan Editor - Share with Group within Organization
I have Indoors configured in Enterprise 11.5. I configured Floor Plan Editor and want to share the plan with a specific group within my Organization. I only see the options for Private and Organization: According to documentation, this should be an optional…
Space Planner - Label Placeholder Occupants
Is there a way to label the placeholder occupants in Space Planner?
Scenario Planning Ideal Workflow for Floor Plan Changes and Occupant Planning
My facilities team is asking for scenario planning capabilities. We're using Floor Plan Editor to create proposed layout changes, and Space Planner for occupant scenario planning. What is the recommended workflow for getting a proposed floor plan layout from Floor Plan Editor into Space Planner so we can experiment with…
Access launch actions from directions in Indoors Viewer
I'm the administrator of a public Indoors Viewer primarily used as a campus navigation tool, offering three travel modes: Walking, Partially Accessible, and Fully Accessible. Our current launch actions include Survey123 forms for issue reporting and general feedback. When a route is not found, especially accessible routes,…
ArcGIS Indoors - QR code starting point vs destination point
We are trying to use Indoors as a navigation tool for our Judicial Complex. We’ve created a POI for each QR-code starting location. However, when we select the POIs and choose ‘Get this information on mobile’ to generate the QR code, Indoors automatically sets that POI as the destination. Is there a way to configure it so…
Add visual booking indicator to monthly calendar
It would be helpful to see a visual indication in the monthly calendar for a unit about whether or not there is availability. For example, a red dot under a date could indicate no availability, an orange dot could indicate partial availability, and a green dot could indicate full availability.
Support time-period (schedule-aware) allocation — persistent, distinct from Workspace Reservations
Use case: Many organizations use the same room for different people and purposes across a repeating daily schedule. A K-12 classroom is Math/Ms. Smith in Period 1 and Science/Mr. Jones in Period 3; clinics rotate exam rooms by shift; labs and shared offices rotate by block. We need the standing plan of record to…
New Blog: Proactive QA Is the Foundation of Reliable Indoor Routing
Proactive QA Is the Foundation of Reliable Indoor Routing Reliable indoor routing is rarely accidental. It's the result of rigorous quality assurance (QA). In complex indoor environments, even subtle connectivity gaps or vertical inconsistencies can lead to failed routes and confusing wayfinding experiences. Visual review…
Add a "Recalculate" button for Allocations
Hello there. On the Allocation tab of the Space Planner, you can add a new Organization Area based on pre-existing values in the ORG_LEVEL_1 field. When these areas are created, any Units with a matching Occupant based on ORG_LEVEL_1 are automatically allocated to that new Org Area. This is great and makes sense, as…
Allowing Mixed-Resolution & Dynamic Allocations in Space Planner
Related to this's post: https://community.esri.com/t5/arcgis-indoors-ideas/multi-level-allocations-in-space-planner/idi-p/1690897/jump-to/first-unread-message. Aaron has highlighted a critical gap, and I want to add some context to why the current single-tier allocation model breaks down in production. At our university,…
Ways to pre-populate Organization Areas list?
I am looking for a way to pre-populate the Organization Area list in the Space Planner - Allocate tab. Right now the software requires manual loading of individual org. I tried to pre-assign units with unique values extracted from the Occupants - ORG_LEVEL_1 field, but Space Planner seems to ignore it (even worse, if it…
Improve 360 Photo UI in Indoors Viewer app
When 360 photos (via Oriented Imagery dataset) are added to the Indoors Viewer app (browser), a button to "Show 360 Photo Locations" becomes available. By default, the symbols for these photo points are hidden from the map until this button is clicked. When the button is clicked, the map is greyed out and the 360 photo…
Space Planner doesn't honor label placement for Occupants
I am very new to Indoors but as my title suggested, the Space Planner app doesn't seem to honor the label rules of my underlying web map. I've configured the label for my Occupants layer from both the feature level as well as in AGOL map viewer but it somehow always reverts to the Upper Right position. Space Planner…
Floor Filter doesn't honor the hosted views created from indoors data
Hello, We are migrating internal business to Portal (11.2, I know its retiring and we have plans to upgrade to 11.5). I have the Indoors dataset published to Portal - it is hosted. From this I have created view layers (both individually and from the grouped service) and in the view layers the floor filter will not show all…
Unit IDs and Level IDs do not Populate Occupant Layer
My organization is looking to create the Indoors Space Planner and Reservation system. I am trying to create the Space Planner app but am struggling with the Indoors Occupants layer. I created a CSV with the required Unit ID, Level ID, Site ID, knownas, title, email etc. My facility is floor aware configured with matching…
