ERROR WHEN TRAINING DEEP MODEL
1835
11
09-21-2022 06:04 PM
AthuleSali
Hello everyone...
I'm new in arcgis pro and am trying to create a deep learning model so now im stuck in training the model and im getting this error:
File "c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx\TrainDeepLearningModel.tool\tool.script.execute.py", line 308, in execute
data_bunch = prepare_data(in_folders, working_dir=out_folder, **prepare_data_kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3-clone-Athu_DL\Lib\site-packages\arcgis\learn\_data.py", line 1440, in prepare_data
raise Exception(
Exception: Could not infer dataset type. Please specify a supported dataset type or ensure that the path contains valid esri files
During handling of the above exception, another exception occurred:
File "c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx\TrainDeepLearningModel.tool\tool.script.execute.py", line 390, in <module>
execute()
File "c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx\TrainDeepLearningModel.tool\tool.script.execute.py", line 384, in execute
del data_bunch
UnboundLocalError: local variable 'data_bunch' referenced before assignment
Failed script (null)...
Failed to execute (TrainDeepLearningModel).
DanPatterson
Which of the required inputs are you using?
Train Deep Learning Model (Image Analyst)—ArcGIS Pro | Documentation
... sort of retired...
AthuleSali
I used the results folder that I got from exported training data for deep learning.
PavanYadav
hi @AthuleSali
This error indicates the issue is with the input data: Exception: Could not infer dataset type. Please specify a supported dataset type or ensure that the path contains valid esri files
Can you please share screen captures the following?
1. input folder contents
2. stats.txt
3. The Train Deep Learning Tool with parameters filled (or, even better if you can share the command. You can copy the python command from the history)?
Pavan
AthuleSali
Hellow @PavanYadav
Thanks for trying to assist, my mistake was really on the input data but I fixed it thank you so much.
AlexaVerónicaGarcíaBarrantes
Hello AthuleSali
Im having the same issue, what did you do to fix it?
GBacon
I'm having the same issue in Pro v3.2.2. There are tiffs in my \images folder and xml files in my \undefined\labels folder. I've tried running the tool with/without the labels folder. Without the labels folder, I get this error, making me think it needs the labels folder.
However, when I try to include my labels folder, I get the error below even though the exported training files used RCNN masks for the metadata format.
@PavanYadav I appreciate any assistance you can offer.
PavanYadav
hello @GBacon sorry that I missed to see your message.
In the Train Deep Learning Model tool, you need to input the entire folder that is created by the Export Training Data For Deep Learning tool
GBacon
Thanks, Pavan. I'm all set now and I have a trained model.
AthuleSali
@PavanYadav can you assist things I can do to get the accurate model? I have have been developing the Unet models since last week and my F1, Precision and Recall are so low. See the attached.
