Ideas in ArcGIS Pro 2.8
4388
05-13-2021 01:26 PM
KoryKramer
Esri Community Moderator
7 5 4,388
As I started writing this post, I thought that it would be fun to find a quote about productivity and I ended up landing on this one from Franz Kafka:
Productivity is being able to do things that you were never able to do before.
Now don't get me wrong, I love Kafka's writings, but it seems to me that he didn't have any experience working with GIS software (fair enough, given that he was born in 1883)!  Anyway, I'm keeping it because it made me laugh given our context here.
For me, and I'm pretty confident for you, productivity is something more like, "I can do this now by copying this here, moving it there, opening this, changing that, and getting what I want, but it would be way better if I could just right-click > duplicate, right?!"
Or, "I can't find the command/tool that I need, why should I have to look in doc or Google it?" or even, "I actually know EXACTLY what I'm looking for, I just don't see why I should have to go up to the ribbon, click a different tab and scan through a bunch of stuff to get there."
Yep, solving gripes like these sound more like productivity improvements to me.  But then again, I wasn't born in 1883, so Kafka might call me crazy.
Based on what we were hearing across different channels including product surveys and Technical Support, as well as from your contributions here in Esri Community, the ArcGIS Pro team determined to make 2.8 a release focused on performance and productivity improvements, with fewer new capabilities than we might expect in a typical release.
On the performance side of the house, the What's New in ArcGIS Pro 2.8 video does a great job showcasing a handful of notable gains (starting at 2:04) - and there are many more that may benefit you depending on your specific ArcGIS Pro projects and workflows.
Many of the productivity improvements are a direct result of the user community's participation in the ArcGIS Pro idea exchange.  In this video, I've bundled up some quick demos of how your ideas were implemented:
Below is each idea that you can look forward to when you upgrade to ArcGIS Pro 2.8.
Most requested:
Scrolling the attribute table in ArcGIS Pro & See Fields while Scrolling Through Attribute Table in ArcPro (6:32)
ArcGIS Pro: symbology for selected polygons (6:21)
Stop having ArcGIS Pro automatically sort attribute domains when editing (5:33)
Analysis and geoprocessing:
Reclassify Rasters in ArcGIS Pro (4:43)
Allow "Convert LAS" to work with LAZ files without a projection (4:05)
Copy as Python Snippet without running tool (3:58)
ArcGIS Pro 2.5: An option to keep the link between the “weighted overlay” tool and its outputs as th...
Data Management:
ArcGIS Pro 2.5: Pro fails to move a column in attribute table beyond the fields visible in the attri... (6:12)
Remove 'Click to add new row' from feature class attribute table (6:00)
Find and replace with nothing in Pro attribute table (5:51)
Project Home button in Pro export GUI (5:24)
Showing the name of the hard drive on the catalog to avoid confusion, (4:25)
Enable the selection of Network Location to Add Folder Connection (4:20)
Add "Recent Places/Quick Access" option in ArcGIS Pro (4:15)
ArcPro Catalog Favorites Functionality (2:40)
ArcGIS Pro Portal My groups categorisation (2:31)
Preview in ArcGIS Pro Catalog View should always display feature class geometry. (2:21)
Display full path for data in ArcGIS Pro (2:15)
During Create Feature Class, Allow 'Click any field above to see its properties'. (2:02)
Import fields not recognizing shapefiles (1:58)
Request error message: Spatial References Do Not Match - when copy/paste FCs to a FDS with a differe... (1:47)
Delete and Remove button are soo close (1:31)
Radial Bearing as Default Option In Traverse Window in ArcGIS PRO (1:09)
COGO Traverse Tool Adjustment Residuals (0:58)
ArcGIS Pro Adjust Traverse (0:55)
Parcel Editor: Update Plan Fields When Appending New Parcels (0:43)
Better Support for Point and Connection Line Subtypes (0:23)
Show Status Bar for Post in ArcGIS Pro
Make ArcPro show correct percentage done when compacting file geodatabases
Ability to Sort/Manually Reorder Favorites in Catalog Pane
Auto adjust attribute table column width to fit the contents
Mapping and Visualization:
Pro: Ctrl+Click/drag to duplicate text/object (5:09)
Align text and graphic elements in layout to last item selected (5:04)
"Copy Map to Clipboard" in ArcGIS Pro? (4:56)
Add search to ArcGIS Pro ribbon (3:50)
ArcGIS Pro: Enable "Add all values" to use format settings from "All Other Values" like ArcMap does. (3:36)
ArcGIS pro: Moving Headings in Legends (3:22)
Creating ADA Compliant PDF Documents (3:06)
Duplicate label class (2:57)
Keyboard Shortcuts for Feature Rectangle in ArcGIS Pro (2:48)
Allow layer files to be elevation sources (1:36)
Arcade function to convert direction in DMS to Decimal degrees (1:17)
Consider supporting voxels at the 3D Analyst License Level
Thank you for sharing your ideas about how to make ArcGIS Pro work better for you.  And a special thank you to the following community members who had ideas implemented this release.  We appreciate and value everyone's contributions!
BlairDeaver3, BrianGreening, BrianRobeson, ChrisMathers1, ChristaVinnemann, ChristopherBowering, CTCadmin, DanielleKulas, DavidWheelock2, DuncanHornby, Geographic_Mythos, GregBazhaw, GregDavis, IreneHwang, JamalNUMAN, James_Whitacre, jcarlson, JeromeHaaland, JonHamalainen, KarlTian, KevinMayall, KJCarpenter, Klaus_Bonnelycke_Vestergaard, LucasBeauchamp, LuciaBarbato1, MarcelSt-Germain, MarkVolz, mhoffman6, MichaelSmith1, MicheleHosking1, PalomaSanchez, RobbynAbbitt, SeanLyons, SeanSweeney, ShelbyZelonisRoberson, SimonKettle, StagiaireCarto, SterlingLoetz5, VladimirZenkl, WilliamPollock, WilliamWright2
Search, Participate, and Create in the ArcGIS Pro idea exchange.
5 Comments
DuncanHornby
MVP Notable Contributor
I've just watched the video and I think you ended on a "slam dunk", the improved table scrolling! This has been a long time coming and will be for me my #1 productivity improvement as much of my work requires me to manipulate large census tables.
I also found it amusing the new functionality of copying graphics, seems like you have created a way to print money! 😉
Thanks for the improvements!
KoryKramer
Well, virtual money is all the rage nowadays! 😋
We realize it took a long time for the table improvement - it was actually a very big project - we hope that it makes everyone's work easier.
Cheers
DavidWheelock2
Occasional Contributor II
Problem with Horizontal Table Scrolling at 2.8.
This was a problem before with Pro.  Now it's different, but even worse.  😯
How to demonstrate the problem:
We're talking about when you click on the horizontal scroll bar between the endpoints and not on the slider to move the table view one page to the right or left.
Let's start with ArcMap.  Previously, ArcMap, and nearly all other table display apps have the following behavior.  When you click the mouse as described above then the table scrolls one horizontal page to the right so that the right-most, partially-visible field is placed at the left side of the table window, fully visible.  This is a very intuitive display strategy and all other apps that I know of use it.
Before:
After:
ArcGIS Pro (Pre 2.8) tried to mimic this but awkwardly failed to properly place the right-most, partially-visible field  on the left side of the table display and usually placed it completely to the left of the visible fields forcing the user to scroll back to the left a little to see it.
Before:
After:
ArcGIS Pro 2.8
Perhaps someone complained about the above problem, because at ArcGIS Pro 2.8 the behavior has been changed as follows.  When you click on the scroll bar, instead of scrolling a whole page to the right, now the table display window only scrolls exactly 55 millimeters to the right, forcing the user to click 3,4,5 times or more to scroll the table one full page to the right, depending on how wide the table display window is.  It always scrolls 55 millimeters left or right regardless of how wide the fields are or how wide the table window is.  In the example below you can see that the table only scrolls about 2 1/2 fields to the right.  Additionally, like pre-2.8 versions, it still suffers from the problem of truncating the field on the left side of the table display window instead of placing the left edge of the field there.
Before:
After:
Do we need to make a new Idea to get this taken care of?
KoryKramer
Thanks, David.  We're looking into this, but for now, it doesn't sound like an appropriate idea.  I'm checking with the development team and will circle back with you soon.
Thank you.
KoryKramer
For the comment about page scrolling in the attribute table, [BUG-000141718: Clicking on the empty scrollbar space, or using the Page Left/Page Right context commands, on a table should scroll a full page of columns.] was submitted with technical support and should show up shortly on support.esri.com.  If other community members happen to discover this thread and are experiencing the same issue, search for that bug number on support.esri.com and click Subscribe to get set up for notifications and increment the count of affected customers in our support system.
Thank you!
About the Author
With an undergraduate degree in Biology and Environmental Studies from Kalamazoo College, I became interested in GIS when working as a land stewardship manager on the Osa Peninsula, Costa Rica. After returning from Costa Rica, I earned a graduate degree in GIS with a focus on Sustainability Management from the University of Washington. As a Product Manager for ArcGIS Pro, collaborating across multiple teams to contribute to the direction of product development, I am dedicated to listening to users and finding ways to convert that feedback into a product that continues to add customer value.
