Consider supporting voxels at the 3D Analyst License Level
3454
08-03-2020 01:29 PM
Status: Implemented
BlairDeaver3
I have both Geostats and 3d extensions but a Standard ArcGIS Pro license.  Why do I need an advanced license to work with Voxels!?!  This seems a bit overkill considering all of the other products I am working with to do sub-surface GIS.  Please Esri reconsider this license check!  Thanks.
3 Comments
Andrew--Johnson
Thank you for this idea. We have communicated this to product management and i'll post back here if there are any changes for the upcoming releases.
regards,
Andrew
Andrew--Johnson
For the ArcGIS Pro 2.8 release, product management has decided to allow voxel layer use at all license levels so there will no longer be any licensing restrictions to display and use a voxel layer.
thanks,
Andrew
Andrew--Johnson
Implemented in ArcGIS Pro 2.8. All licensing restrictions have been removed for voxel layers.
