How to center a group of calcite cards?
212
04-23-2024 10:07 AM
SamGuilford
Hi @KlaraSchmitt - I'm addressing this you, because I see you've answered a lot of Hubs Calcite questions.
I'm using a Card Group similar to the example here, where there are five total cards - three in the first row, and two below. (I'm using a card-shaped class, sample code below). Instead of having everything left-justified, I'd like everything to be centered. So on a medium/large screen, the bottom two are centered under the top three, and as the layout adapts with smaller sizes, the cards keep centering.
I've tried a number of things, including creating a style that includes align-content: center !important and tried wrapping that round the last two cards, but that didn't work.
What's the easiest way to do this?
<div class="col-xs-12 col-sm-6 col-md-4">
<div class="calcite-web">
<div class="card-base card-shaped">
<figure class="card-image-wrap">
<img class="card-image" src="https://hubqacdn.arcgis.com/opendata-ui/assets/assets/images/bridge3-ab9c41a43f1bf4379a90134a0658f4c...">
</figure>
<div class="card-content">
<h5>
<calcite-link href="https://www.google.com" rel="noopener" role="presentation" calcite-hydrated=""><div style="text-align: center;"><b style="font-family: var(--fontsHeadingFamily),Avenir Next; font-size: var(--font-size-h5); background-color: initial;">Conservation</b></div></calcite-link>
</h5>
<div class="credit">
<calcite-chip id="photo-1" value="calcite chip" icon="camera" scale="xs" appearance="solid" kind="neutral" calcite-hydrated="" aria-describedby="calcite-tooltip-44aad912-5c4c-8698-6042-ccb2d322a8b8"></calcite-chip>
</div>
</div>
</div>
</div>
</div>
lmarun
I have exactly the same question. I've tried several approaches, including the center aligning and an adaptation of this (but keeping the images and text otherwise unchanged), with no success.
It seems like this should be something that does not require coding, as there is no reason to think three is always the number of cards a person will want. Perhaps having an option to use anywhere between two and five or so should be offered, and the cards should accommodate and center accordingly (just my two cents).
Either way, I echo @SamGuilford's question. Any help is greatly appreciated!
