ArcGIS GeoBIM Questions
122
404.5K
50
| Open | Please add a unit override/scaling capability in the GeoBIM → AGOL integration so ACC-hosted 3D models authored in Au... by LoutKuiper_2 Emerging Contributor 0 1 | 0 | 1 | |
| Open | My company currently does no use cloud storage for our BIM or CAD files, so whilst we have AutoCAD Civil 3D and Revit... by LaurenAlt Regular Contributor 0 1 | 0 | 1 | |
| Implemented | In the Scene Viewer (and therefore also in the GeoBIM-App) the visibility of different scene layers interferes in an ... by AndreasDorsch Emerging Contributor 0 1 | 0 | 1 | |
| Closed | Please offer, additional or instead of choosing a basemap, choosing a projection directly within the setup of a GeoBI... by AndreasDorsch Emerging Contributor 0 1 | 0 | 1 | |
| Open | Following on from this question: https://community.esri.com/t5/arcgis-geobim-questions/supported-bim-cloud-connection... by MappyIan Frequent Contributor 0 0 | 0 | 0 | |
| Open | I think it would make sense to be able to make use of Revit Views when processing a Revit File in GeoBIM and Preproc... by FCL Emerging Contributor 4 0 | 4 | 0 | |
| Open | In the work processes the BIM teams deliver products (rvt, ifc, dwg, pdf) and depending on the status of a product, i... by Stefan_Thorn Frequent Contributor 1 0 | 1 | 0 | |
| Needs Clarification | Portion of workflow: After a model has been linked and is being viewed in an application.Situation: The forge viewer ... by Treavon Regular Contributor 0 3 | 0 | 3 | |
| Open | As written in this post in the ArcGIS GeoBIM community, now it is only possible to place an issue on a layered surfac... by lorenzoz Occasional Contributor 5 0 | 5 | 0 | |
| Open | Esri should build a similar cloud-to-cloud integration with SharePoint! by Micah-Callough Occasional Contributor 2 2 | 2 | 2 |
Idea Submission Guidelines
