When BIM and GIS Stay Connected: Watch our Autodesk University session on demand
Missed us at Autodesk University 2026? Our session recording is now available! In “When BIM and GIS Stay Connected: Esri and Autodesk’s Path to True Cloud Interoperability,” @MichaelDavidsonPM and I introduced some exciting R&D initiatives we're pursuing at Esri to fundamentally change how BIM and GIS data connect across…
Support Toposolids from REVIT
Support Toposolids from REVIT as a feature similar to other REVIT model types to allow for a succinct import and georeference of BIM data as a whole.
Schedule the Sync Process
For an app that provides information for Project Managers, Construction Managers, Directors, C-Levels and Stakeholders that don't know or don't care about the techinical steps to visualize the information, the need of an GIS analyst to sync the information every time all people involved want to see or present the app to…
Add Document Models - blocking revit files
Environment We are currently testing ArcGIS GeoBIM with Autodesk Forma (ACC) on a large transportation infrastructure project. Our workflow uses: * Autodesk Forma / ACC as the Common Data Environment (CDE) * Revit Cloud Models * ArcGIS GeoBIM * Shared project folders within Autodesk Forma * Geo-referenced Revit models with…
ArcGIS GeoBIM on ArcGIS Enterprise deployment troubleshooting
Welcome to the troubleshooting guide for deployment issues when using ArcGIS GeoBIM on ArcGIS Enterprise. This article aims to offer guidance on errors that may occur due to missing or misconfigured Enterprise infrastructure, services, or deployment settings. General deployment errors Use the information below to…
ArcGIS GeoBIM Tools troubleshooting
Welcome to the troubleshooting guide for the ArcGIS GeoBIM Tools. This article aims to provide you with clear and actionable solutions to help identify and resolve issues that you may encounter while synchronizing Autodesk Forma data into ArcGIS GeoBIM. Note: As of the ArcGIS Online July 2026 update, the Analyze feature…
ArcGIS GeoBIM UI error troubleshooting
Welcome to the troubleshooting guide for ArcGIS GeoBIM UI errors. While many interface messages are straightforward, some may require extra guidance to workaround or resolve. Use the information below to troubleshoot the common UI errors experienced within ArcGIS GeoBIM. Error message Error description Troubleshooting Fail…
What's New in ArcGIS GeoBIM - June 2026 (ArcGIS Online)
Note: This blog was originally published on June 25, 2026, alongside the ArcGIS Online release. It was updated to include additional features released on July 30, 2026, outside the standard ArcGIS GeoBIM release cycle. _____________________________________________________________________________________________ The June…
Notice for ArcGIS GeoBIM Users: Updated Autodesk Authorization Request
There has been a change in the Autodesk authorization request shown when using ArcGIS GeoBIM. ArcGIS GeoBIM now requests Autodesk permissions more narrowly. Most GeoBIM workflows only require read-only access to Autodesk data. The only exception is creating Autodesk Issues, which requires write access. As part of this…
Notice for ArcGIS GeoBIM Enterprise Users: APS Developer Hub Changes
We are aware that recent changes to the Autodesk Platform Services (APS) Developer Hub are affecting customers who are deploying ArcGIS GeoBIM in an Enterprise environment. As part of these changes, creating an APS app now requires providing payment information, even when using the free tier. Our team is currently working…
GeoBIM Integration Issue with Autodesk BIM360
Hi Everyone, We have implemented ArcGIS Enterprise base deployment and installed Enterprise 11.3 and GeoBIM. To integrate Autodesk BIM360 and ACC with GeoBIM, we have referred to the following documentation: https://doc.arcgis.com/en/geobim/11.3/get-started/geoprocessing-sevice-installation-for-enterprise.htm…
What's New in ArcGIS GeoBIM - February 2026 (ArcGIS Online)
Update March 2026: We've added an additional enhancement to the Document Explorer Widget on Experience Builder. Read below for more information. _____________________________________________________________________________________________________________________ The February 2026 release of ArcGIS GeoBIM introduces key…
RESOLVED: Error message when running the Tools on ArcGIS GeoBIM for Enterprise
Update 01/14/2026, 02:30pm EST - Issue has been fixed and there are no actions required by users to implement the fix. ---------------------------------------------------------------------------------------------------------------------------- We are aware that Enterprise users are experiencing issues with the Tools page…
GeoBIM - Add Document Models
Hi, I am using GeoBIM with AGOL. I am connecting to ACC and trying to add IFC files by using the "Add Document Models" . In the Setting of "Add document Extents" I am using the Default WKID as 3997 as the IFC model is in the Dubai Local Transverse Mercator and I am adding the 3D MODELS FROM "Add Document Models (Beta)".…
What's New in ArcGIS GeoBIM on ArcGIS Enterprise 12.0
The November 2025 release of ArcGIS GeoBIM on ArcGIS Enterprise 12.0 streamlines GIS and BIM integration with simplified 3D models, expands flexibility for building custom web apps, and adds support for more file formats. For more details about this release, be sure to read the What’s New in ArcGIS GeoBIM November 2025…
Selecting Issue in Charts does not filter the issue in the table and Map/Scene Viewer
When I click and select the Open status in the serial chart. The issues in the table and scene/map viewer does not respond to my selection. Does anyone having this issue? or am I missing a step?
What's New in ArcGIS GeoBIM - October 2025 (ArcGIS Online)
The October 2025 release of ArcGIS GeoBIM introduces enhancements to existing tools and capabilities, along with expanded support for new Autodesk Construction Cloud (ACC) regions. Add Document Model Tool (Beta) – Improved Location and Alignment The Add Document Model tool (still in beta) creates simplified 3D models from…
ACC → AGOL: Add unit override and scaling to support Plant 3D
Please add a unit override/scaling capability in the GeoBIM → AGOL integration so ACC-hosted 3D models authored in Autodesk Plant 3D (millimeters) can be correctly placed in AGOL projects using meters (e.g., RD New / EPSG:28992), without breaking the live ACC link. Problem: * Plant 3D models are typically authored in…
GeoBIM for non-cloud connection to BIM data
My company currently does no use cloud storage for our BIM or CAD files, so whilst we have AutoCAD Civil 3D and Revit, we don't have Construction Cloud. The tools and functions of GeoBIM look amazing, but it can't be used without a cloud connection. It would be excellent if this tool could be used with local…
The selected feature dose not have a link define
Hello everyone, I am trying to link my scene layer to Autodesk Construction Cloud (ACC) documents using the "Create a Viewer URL Rule" option in ArcGIS GeoBIM. However, when I select a specific feature, I receive the following error: "The selected feature does not have a link defined" Has anyone encountered this issue…
GIS & BIM at Esri's 2025 User Conference
Esri's 2025 User Conference is fast approaching, and we've put together a detailed agenda of all BIM and GIS-related sessions. Check out the latest updates on ArcGIS GeoBIM and other GIS and BIM capabilities across ArcGIS - and stop by the ArcGIS GeoBIM and ArcGIS for Autodesk booths to say hello! ➡️Read more in the GIS…
What's New in ArcGIS GeoBIM - June 2025 (ArcGIS Online)
The June 2025 release of ArcGIS GeoBIM includes new tools and expanded capabilities for working with BIM and GIS data. For more details about this release, be sure to read the What's New in ArcGIS GeoBIM June 2025 blog article. Add Document Models tool (beta) This tool creates simplified 3D models from Autodesk Revit and…
Existing and Historical Known Issues
This post tracks existing and historical known issues affecting GeoBIM. It’s updated regularly to help you stay informed and avoid duplicate reports. How to Use This Post * Check first: Review the “Existing Known Issues” table before reporting a new issue. * Report issues: Post new issues on the ArcGIS GeoBIM…
Supported File Formats
The ArcGIS GeoBIM geoprocessing tools support several file formats from Autodesk Forma. See the table below for the most up to date information on the files supported per version of ArcGIS GeoBIM, release versions, and additional resources. Note: We typically add support for the latest Revit version within one or two…
Trying to Change Spatial Reference of a GeoBIM project
I recently have started working in GeoBIM and my company does most of our work in state plane coordinates. Namely, we use KY state plane FIPS 1601. Im not a surveyor just a developer. When I spatially reference the Revit models and pull them into GeoBIM through ACC, The models show up in Virginia, rather than Downtown…
