When will ArcGIS map be enabled in Power BI embedded and publish to web?
4091
11
05-14-2018 10:31 PM
vishnusuresh
ArcGIS map is great to use and is way better than the Bing map in Power BI, But it is not enabled for both embbeded power BI reports and publish to web reports.
Do you guys have a timeline for this feature?
BilelKhelil
Hello do you think it is possible to restrict my address to the city of Paris?
JonEmch
If you have a city field in your data, you should be able to filter the dataset to Paris using PowerBI's build in filters: see the following https://docs.microsoft.com/en-us/power-bi/create-reports/power-bi-report-add-filter
Keep on keeping on!
