Using a rest Service with power bi
4552
01-12-2023 06:49 AM
DiegoLlamasOlivares
Hello
My name is Diego Llamas,and I have a question.
Is it possible to work with rest end point in power bi?
I am clic get data in fields, then select data from web and I add this url https://mapas.policia.pr.gov/server/rest/services/Hosted/CuartelesEstatales/FeatureServer but if i use it like this,  I got an error saying “access to the resource is forbidden”
So I add to the service a token:  https://mapas.policia.pr.gov/server/rest/services/Hosted/CuartelesEstatales/FeatureServer?f=json&tok...Token
And I am able to access the service adding the token and this table is open
And when I apply that table I got his table, these are functions and not the field from the attribute table.
i cannot do anything with this information. Is it possible to get data from a rest service? if yes, do i need to add always a token? can i bypass this token because recreate the map because the token expired is going to be a pain. am i doing something wrong?
Regards,
Diego Llamas
AW_Grove
Hi @DiegoLlamasOlivares  -
I have been successful following this method for unsecure services: https://resource.esriuk.com/blog/how-to-use-arcgis-with-power-bi/
And this method for secured services:
https://community.esri.com/t5/arcgis-online-questions/using-excel-to-access-arcgis-online-automated/...
The second option so far has been limited to Power BI desktop instead of a data flow - so I am really interested if you find out a better way to do this.
sschmitzleuffen_icrc
I am wondering if there is any new news on this?
On my side, I would like to connect to a REST Service from an SDE Database. I do not see any options  in ArcGIS for Power BI to do that. I found a workaround for points with Power Query that "unpacks" the REST service and then enables me to project X and Y on a Power BI viz on the fly. It however seems impossible with lines or polygons.
Anybody found a miracle solution?
Best,
Sven
