slicers selection is not applying to argics maps in publish mode
746
05-12-2021 10:54 AM
DileepKumar
slicers selections are not applying to argics maps after report publishing to server .while other visualizations are working fine.
In power BI service edit mode, Slicers are working for few mins after choosing columns in layer joins area. After saving  the report, again slicers stopped applying for Argics Maps,
Kindly help.
Dileep.
JonEmch
Hello Dileep,
    Are you able to log a case with technical support? this sounds like it may be a defect (or at the very least should be investigated and troubleshot)
Keep on keeping on!
