How to reset map selection when I change a slicer?
1478
11-13-2023 07:24 AM
YonghyeonKweon
Hello,
I am using the lasso function on the ArcGIS map for Power BI to select specific circles on the map. Then my table will be updated with the values from the selected circles.
But if I choose a different value from the slicer, the table will be blank because it is still stuck on the selected circles from the previous slicer value. Is there any workaround to resolve this issue?
Thank you!
slicer:
NaZhang_Esri
Hi @YonghyeonKweon,
Thanks for your question! I tried to reproduce the workflow you mentioned -
1. Add ArcGIS for Power BI, Power BI table and slicer visuals on the report
2. Make selections in ArcGIS for Power BI
- Table will be updated accordingly based on the selections in ArcGIS for Power BI
3. Select a value in the Slicer
- The features from ArcGIS for Power BI will be filtered
- The table will be blank
ArcGIS for Power BI visual works as expected. I'm not quite sure why the table visual is blank but I noticed that if I clicked on the non-features area in ArcGIS for Power BI, the table will be responded. And if changing to another  Slicer value, the table visual will be updated.
NaZhang_Esri
Hi @YonghyeonKweon,
