Changing from AGOL to Enterprise in PBI?
683
11-13-2023 08:58 AM
KevinDunlop
Is there a way to change where the ArcGIS for PBI login points?  Currently, once you select AGOL or Enterprise, you can't switch it.  I often have users who create maps using AGOL option, only to realize later that they meant to use Enterprise.  Our current recommendation is to delete the visualization and recreate with the other login type.  There has to be a better way to do this.
AnthonyLatini
@KevinDunlop - At the moment, the current workflow is to remove the visual completely to switch between an ArcGIS Online account and an ArcGIS Enterprise. Because of infrastructure limitations, this is the current workflow. As a group we are looking to enhance this feature and process by the end of Q1 2024 (think before the 2024 Esri User Conference).
Please bear with us while we work toward making this a better experience.
