Can I create a Buffer for two layers at a same time in POWER BI?
1808
04-27-2023 05:24 AM
Mitina1997
I am trying to create a buffer on point shapefile but when I try to create another buffer for different layer it removes the older one and create the buffer for second layer.
Can it create two buffer shapefile at the same time?
dcallaghan
I don't think it is possible to have two concurrent buffers within PowerBI. I think you would need to create the buffers you need in ArcGIS Online and then add them to the map as separate layers.
AnthonyLatini
Hello @Mitina1997 ! As mentioned by @dcallaghan , you can only create one drive time buffer at a time within the ArcGIS for Power BI. This is the current limit in the component and is set that way due to the infrastructure and ecosystem within Power BI.
