Requirements to use power automate
947
08-24-2023 04:41 PM
bryan_hope
Hello
I have purchased the student version to evaluate arcgis.  I was hoping to use power automate to create feature layers since I have a lot of data inside sharepoint lists and other microsoft resources. Is it possible to do this with a student subscription or is a higher-level subscription required?
Thank You
Tags (1)
2 Solutions
SeanKMcGinnis
Good Day @bryan_hope  - to expand on @HeatherSmith’s response, you should be able to use the ArcGIS Connectors for Power Automate with your student evaluation license if you have a full license of Microsoft’s Power Automate. Microsoft considers certain connectors as third party connectors, and as such requires a full license of Power Automate, here are the details on the different levels of licensing and what they provide.
I hope this helps,
-sean
Sean McGinnis - ArcGIS for Microsoft 365 Product Manager
AdenaSchutzberg1
Hello Bryan,
Yes, your ArcGIS for Student Use license provides an ArcGIS organizational account, so you can use it with Microsoft's Power Automate. See Get started with ArcGIS Connectors for Power Automate for further information.
You can also post questions about ArcGIS Connectors for Power Automate in this ArcGIS for Power Automate Questions board.
HeatherSmith
@bryan_hope I'm not sure how this question became separated from its answer, but please see the response here: https://community.esri.com/t5/learn-arcgis-questions/re-requirements-to-use-power-automate/m-p/13224...
SeanKMcGinnis
I hope this helps,
-sean
AdenaSchutzberg1
Hello Bryan,
