What goes in the Data field of the Get data from feature layer action?
I'm pulling my hair out between esri and Microsoft. With the change to the layer-based triggers away from app triggers (Survey123) more loops are required and I've run up against the nesting limit in Power Automate. The fix for that is to set up a solution in the Power Platforms environment and then you create parent/child…
Need a way to compare previous attribute to current attribute
We would like to use the ArcGIS Connectors for Power Automate to send emails when the status of a feature changes. For example, a permit's status changes from submitted to assigned we would like the permit applicant to get an email letting them know that their permit is being processed. We currently cannot find a way to do…
ArcGIS Connector "refresh" flow no longer working
Hello - I have a flow that I created in 2023 to automatically refresh my ArcGIS Connector token. I followed the instructions in this blog by Sean McGinnis and it has worked well until September. I am not sure if something changed in my tenant, or if the structure of this flow is no longer valid as outlined in the blog. I…
Feature Service Table Attachment to SharePoint File Save
Hello, I'm working with Power Automate for the first time and I know my use case is common and possible but haven't been able to make it work yet. The workflow is that I have an app created with the ArcGIS SDK for Javascript where a user can fill out a document upload form with metadata about the document, including which…
ResponseSwaggerSchemaValidationFailure error with "When a record is created" and "Fetch updates, changes or deletions..."
Hello - I am working on rebuilding some flows that had been using the "When a HTTP request is received" trigger to use the new ArcGIS Connector, which was not available when these automations were created. My "When a HTTP request is received" automations have stopped working, and I thought this would be a good opportunity…
ArcGIS Connectors for Power Automate UC 2026 Session recordings are available
Quick update: The Session recordings are available for ArcGIS connectors for Power Automate related sessions. You can log in to your conference portal to find the recordings for following sessions: ArcGIS Connectors for Power Automate: An Overview Enhancing ArcGIS for Power BI with the ArcGIS Connectors for Power Automate…
Action to Change Projection
Right now in Power Automate if I geocode with World Geocoder using Find Address Candidates it returns the coordinates system 4326 and if I want to change that projection I have to use HTTP action to connect to the Esri API https://utility.arcgis.com/ArcGIS/rest/services/Utilities/Geometry/GeometryServer/project which…
Webhook on GP Service - Error: Unable to create or update webhook. URL is not reachable
Hello, I've been struggling with a custom print service occasionally failing/timing out and I want to figure out just how often this is happening, so I thought to try setting up a webhook to email me when the tool runs. I'm working in local government on Power Automate, Enterprise 11.5. I've successfully set up a few PA…
Add action to execute Geoprocessing service from Power Automate
I would really like to be able to set up a flow that could execute a geoprocessing service via power automate. It seems like it may be possible via http request, but my organization is not set up in a way that would make that work. My current usecase is this: * Select all new records that meet X criteria * Run…
Bad Request Error 400 On all flows Using Fetch updates, changes, or deletions from feature layer.
I'm using Power Automate to run multiple flows and regularly getting a failed flow where I get a Bad Request Error 400 on a Fetch Updates, changes or deletions from feature. I tried increasing the number of retries but I don't think that is the issue here as it can't reach the service so it won't retry. If I manually…
Preview Sample Report
Enable an action to preview sample reports in Power Automate. Sample reports are available through through the Survey123 web app. This would be helpful for troubleshooting and configuring report automation flows without consuming credits.
Add ability to read and write to tables from feature services
I want to be able to read and write to a standalone table that is part of my feature service in ArcGIS Enterprise. However, when I connect to my feature service using the "Get data from feature layer" action, I do not see the tables in my service. I only see the feature layers (aka points, lines, polygons). It appears the…
AGOL and Enterprise 'Get data' connectors unable to query by numeric strings
When setting a query on 'Get data from feature layer' connectors, using a numeric string as the search value returns an empty body (when I'm positive that features with the search value exist in the feature layer, and the field type is String). I've tried every formatting/conversion iteration I can think of (enclosing the…
Get Attachment action returning 404 for valid feature attachments
Hello, I am experiencing an issue with the ArcGIS connector in Power Automate that appears to have started recently. I have a flow that has been working successfully for several months. The flow retrieves records from a hosted feature layer and then uses the Get Attachment action to download the associated photo…
ArcGIS Connector (Release 2026.2) API Keys stopped working
Sometime on 7th, all my newly updated flows that use the new connector with API Keys stopped working. The connector(s) shows as green; however, my flow has an unauthorized error message. I tried to refresh the connector; however, it no longer allows me to update the API key. It forces me to AGOL credentials. It appears…
Fetch updates, changes, or deletions from feature layer now requires a new Parameter
I had a flow that has been working up until 6/2 and I just went and checked and now it is throwing an error because the Data parameter is blank in the Fetch updates, changes, or deletions from feature layer action. I can't find any documentation on this change or what the Data parameter is supposed to be. Any suggestions?
What’s new in the 2026.2 release of ArcGIS Connectors for Power Automate
We’re excited to share the 2026.2 release of ArcGIS Connectors for Power Automate. This update brings meaningful improvements from new API key support to better feature layer filtering and premium feature service support. Release highlights * API key authentication for the ArcGIS Online (ArcGIS) connector We are most…
⚠️ Authentication Issue with ArcGIS Connector (Release 2026.2)
:warning: Authentication Issue with ArcGIS Connector (Release 2026.2) Post has been moved to the ArcGIS Power Automate Blogs
✅Resolved: Authentication Issue with ArcGIS Connector (Release 2026.2)
With the 2026.2 release, we introduced API Key Authentication to the ArcGIS Connector. Following this update, we are observing an issue where existing authentications appear as “connected” but shows errors in existing flows. During pre-release validation, we worked closely with Microsoft and did not encounter this behavior…
Power Automate Connections Failing
Hello, Around 3pm MST yesterday, all of my Power Automate flows started failing. My connections are unable to pull data, even though they still show as connected to my credentials. I added new connections and an API key to see if that would resolve the issue, but I’m still getting the same errors. Here is one example:…
All connections stopped authenticating although they say they are connected - will not let us Switch Account
Seems like at about 2pm all of our connections stopped working. They all return unauthorized and will not let us Switch Account. If I create a new connection it seems to work but we have dozens of flows and it is not realistic to update with new connections.
How do I geocode addresses in Power Automate?
I have a flow set up to take address from an excel table and geocode it. However every time I run this the error is Bad Request. AI seems to say I need to input JSON into the addresses field and not a string for the address, but still results in Bad Request. I can't find ANY documentation. So just wondering if someone here…
Get Centroid Geometry from Polygon in Power Automate
Add create centroid to Create Geometry I'd like to query a parcel data base to add a point location for a permit, automatically as they are added to a table. However, this seems to require like 7 steps to take the polygon geometry and generate some form of a centroid point from the Parcel Rings. I haven't actually figured…
Feature layer choices in Trigger end at "N" and I can't select my needed layer
I've been having trouble with my Flow working, and to help troubleshoot, I want to try reconnecting to my Feature Layer in the drop-down list. When I click on my Trigger ("When a record is updated in a feature layer"), the feature layer that is listed has weird formatting (see image). When I remove the layer to select it…
Add attachment stopped working
As of two days ago, my Add Attachment (Enterprise) step stopped working. No other components of this connecter are affected (e.g., Query Attachment, Delete Attachment, Update a record in a feature layer, etc.). I get a generic 403 error: { "statusCode": 403, "headers": { "x-ms-environment-id": "", "x-ms-tenant-id": "",…
