Problem with multiple tables on Experience builder
3756
9
06-30-2021 10:30 PM
JoseBarrios1
Hello AGOL community,
Does anyone having problems with tables with the recent June update on experience builder? I had several tables on multiple pages and I can only see one table in the first page. The tables on the other pages are blank. If I refresh the browser in the active pages, the tables show up but it disappear on the other pages. Also, if I add a filter to a table in one page, it affects all the other tables on the other pages. The tables are the same data layer with different data views.  If I create a copy of the data layer, I can add and see the tables...but that mean that I would have to copy the same layer 4 times. Does anyone know if this is a bug? What I'm doing wrong? Thanks for any help!
JB
TianWen
The "table blank" problem should have been fixed.
It is as designed that a filter would affect those tables using the same data source. Configuring tables with different copies of the data is a good workaround!
TianWen
Thanks for reporting this! It's a known problem and will be fixed very soon.
JosZwambach1
I have the same problem. A very simple experience builder site with just one table and the table is blank and not showing any records.
TianWen
It has been fixed. Let me know if you still see the problem. Thanks!
JosZwambach1
It still does not show the records in the table widhet. The option “Open widgets when the page is loaded” is “None”. When I change this setting to the table the records are visible in the widget.
TianWen
Sorry, the latest code is not delivered yet. I'll let you know once it is done. 🙂
TianWen
JosZwambach1
Thanks. It’s working, the table is filled with records.
JoseBarrios1
Hi TianWen,
Thank you for the follow up on the "blank table issue". It is working now. However, I still having the problem with a filter in one page affecting all the tables in ALL other pages (same issues with maps widgets). I use the same table 4 times (with different views) in different pages. With the "workaround"  I will have to publish the same hosted table 4 times. Do you know if this is a known bug? It does not make any sense for a filter in one page to affect  the content on all other pages.
JB
TianWen
This is an as-designed behavior for now. We'll consider your cases and see whether we can make any enhancements.
