Hide Variable/Curly Bracket Until Selected
11810
22
04-07-2020 06:20 AM
DevinLavigne
In the Text Widget/Dynamic Text is there a way to hide the variable and the curly brackets until something is selected? Or a way to write an expression - i.e. If {County} = "" Then "" Else {County}? Seems like this should be easy but I'm not seeing anything. Thanks.
MelissaBrooks
Hi David, when is the next release planned?
Cheers
Melissa
Melissa Brooks
Senior Geospatial Systems Specialist
Tasman District Council (New Zealand)
DavidMartinez
Hi Melissa, we just released the second week of April and our next release will be at the end of June. The option to use selected features with the Feature Info widget I mention above is in the current release.
Cheers,
David
MelissaBrooks
I miss read the workaround, my scenario is akin to an asset viewer, so to select the first in a default view as a default value would end up misrepresenting what is on the map/expbuilder app and cause confusion to the user, UX would essentially be poor. is there a way to just show a default text of ""/nothing until clicked or when nothing is selection rather than the curly bracket {fieldname} as described above?  Thanks for your time,
Cheers
Melissa
(New Plymouth District Council, NZ)
Melissa Brooks
