How about the performance of ArcGIS Enterprise with 4 Cores licensing that is installed on a server machine with 64 cores?
784
01-28-2020 05:10 PM
JamalNUMAN
Legendary Contributor
I couldn’t figure out how the number of cores licensing is affecting the performance (or whatever else) of the ArcGIS Enterprise.
For example, how the ArcGIS Enterprise with 4 Cores licensing that is installed on a server machine with 64 cores is different from the ArcGIS Enterprise with 8 Cores licensing that is installed on a same server machine (64 cores)?
Jamal Numan
JoshuaBixby
MVP Esteemed Contributor
Core licensing is a licensing issue and not a technical issue, i.e., the ArcGIS Server service either is not aware of the core licensing or doesn't adhere to it.  If you install ArcGIS GIS Server on a machine with 64 cores and license it with a 4-core license, it will use as many of the 64 cores as it can.
There are multiple strategies for remaining compliant with licensing ranging from purchasing more licenses (license cores) to sizing VMs to fit existing licenses to using CPU affinity/pinning.
jill_es
Jamal, Joshua is correct - the ArcGIS Server service isn't "aware" of the core licensing in the way you described.  The performance issues you're encountering aren't due to the licensing of ArcGIS Enterprise; they could be attributed to environment variables, how ArcGIS Enterprise is set-up, etc.  We'd need more information to be sure.
Do keep in mind that this would be in violation of your license agreement until you purchase a license for the additional cores.  This is explained further in this whitepaper.
