Hello - I tried scheduling the Living Atlas update 2025.1 for my 11.4 Enterprise Portal. I went to Organization>Settings>Living Atlas>Schedule update for April 22, 7pm EDT, but nothing happened.
This morning, the Organization>Settings>Living Atlas page still shows me at:
Hi there,
Sorry to hear the update failed.
I would review the Portal Admin Logs from the time when the update was intended to run to see if there was noted issue that could have prevented the update running at the scheduled time.
If you were to trigger the update manually, it might throw an error within the Portal UI and if it does then this might help to explain why the scheduled update didn't occur as you were expecting.
It could also be worth exploring whether the REST API can be used for your scheduling workflow. Going through this route require Administrative access and may prevent a role / permission discrepancy (it could be that the update was scheduled using a pseudo admin role as opposed to a full admin).
Hope you get on ok this time around!
Hi @RobertCollins - thanks for the reply. We have Monitor, showing no issues for the portal logs at the scheduled time. It's possible there was simply a network hiccup on our end as a manual update went fine. I'd have to start checking event logs.
But for us it doesn't really matter as far as scheduling goes, as I need to update sharing on living atlas layers in our basemap gallery after an update, so a manual update is more suited for our work.
