Unable to create new Spatial ETL tool
4422
8
09-21-2022 01:38 PM
ChazArmijo
Hello, i'm trying to create my first Spatial ETL tool and i'm having trouble with an early step in the documentation. I'm not seeing Spatial ETL Tool as an option. I do have a license checked out. Anything else i'm missing?
This is what i'm seeing after creating a toolset
and i'm seeing the same when right clicking a toolbox and selecting new.
Thanks for the help!
BruceHarold
Esri Frequent Contributor
Are your Pro and Data Interoperability installations at the same release?  I see an atbx in your project but 2.9 for Data Interoperability.
RenatoSalvaleon3
Using Data Interoperability requires installing the product extension too.   Did you install Data Interop? Check with you account manager or my.esri.com if you have download access to ESRI products.
ChazArmijo
Yeah, I did install the product extension as well. I'll try restarting my machine since I haven't since installing it.
BruceHarold
ChazArmijo
it looks like my pro installation is behind my DI installation. I'll see what i can do to align them. Thanks!
RenatoSalvaleon3
To add to Bruce comment.  DI is supported only by TBX tools in 2.9; in 3.0 both TBX and ATBX formats are supported, although you will not be able to create new legacy toolboxes (tbx) anymore in 3.0 but can still use them in your 3.0 projects. A bit of transition with this new format.
CTardif
So is there a version of the Data Interoperability extension that works with ArcGIS pro 3x?
BruceHarold
Yes of course, Data Interop for Pro works, you just have to make sure you install at the same release.
JonathanDandois
I am on Pro 3.0.3 and my Organization provided the Data Interoperability installer for 3.0, but i get an error in the install. Do I need another version of the Data Interop installer?
Update: I got the 3.0.3 installer from my Org. woot!
