One of the layers in Dashboard is not filtering
1932
7
04-20-2021 11:32 AM
MayraHernandez
New Contributor III
Hello, I created a dashboard that includes a date selector. It has several actions that filter the map layers, charts and indicators when a date is selected. I noticed that one of the layers (heat map layer) does not filter when a date is selected. The heat map layer is listed in the Date Selector “Actions” list. I noticed this happened after there was an update to the date selector.
RolandoFernandez
New Contributor III
Hello Mayra,
Do you try including your Date Selector in the filter actions of your Heat Map ?
Best Regards from Venezuela !
MayraHernandez
New Contributor III
Hello Rolando from Venezuela,
Thank you for your response.
There is no option for a Date Selector in the Heat Map actions filter.
RyanStad
New Contributor II
I am noticing the same behavior.  Waiting to hear back from ESRI support.
MayraHernandez
New Contributor III
Hi @RyanStad, please let me know if they are able to find a solution. 😊
TimothyRudzik
New Contributor III
This worked for us on 10.8.1 but no longer works for us on 10.9.1. I have found that if I change the heat map symbology to a point symbology that the filter works again. But I would rather have the heat map symbology AND be able to filter it. Any updates from ESRI on this issue? Is it a known bug?
RyanStad
New Contributor II
Not sure what your setup is but this is working now.  I'm on 10.9.1 using a map service hosted locally with the maps and dashboard published in ArcGIS Online.  Maybe try a new map and dashboard from scratch.
TimothyRudzik
New Contributor III
We are also on 10.9.1 but our feature layer is hosted on ArcGIS Server and we are using Portal / Dashboards (new). Since you are using Dashboards on ArcGIS Online I am guessing it is a newer version than Dashboard in Portal 10.9.1.
I did do a clean test where I published a new feature service then created a new map in Portal then created a new dashboard referencing the new map. The filter action is available but will not filter a heat map layer. However if I change the layer symbology to anything other than head map then the filter action will work in Dashboard.
